Probably need to rebuild a gateway for V3
I need some advice on the best gateway build for V3 to run on a Raspberry Pi 3+ with a rhf0m301 concentrator board from Seed Studio.
I’ve had it since 2018. There was some trouble early on with the original gateway build. It was rebuilt with the TTN Gateway software using the TTN packet forwarder. It’s been running on V2 since then, very stable, only needing an occasional reboot after a power outage. (I suspect the gateway sometimes comes up before my rural WiFi broadband service reconnects).
I already have another gateway in V3, but I’d like to get this one up and running as a backup indoor gateway on V3. I’m not going to try to get the current setup running on V3. Any recommendations on a good gateway build to use with this hardware?
Did you try the Basics Station application we made with balena?
I never tried your LoRa concentrator, but that should work. You can find more detailed instructions here
