Pq: database "ttn_lorawan" does not exist, *again*
Previous topic closed (https://www.thethingsnetwork.org/forum/t/pq-database-ttn-lorawan-does-not-exist/55737), so reopening here.
The fix there worked for a while. Re-starting TTS then “complained” of having a newer version, so replaced the version in docker-compose.yml and now I get the same message again, whichever version I use (3.18.1, 3.18, 3.18.0, latest). I restarted from scratch, to no avail.
Any ideas?
TIA
Fred
Perhaps @benolayinka, the TTS speed installer, can help out here?
I wonder if there is something wrong with a server somewhere (or access to one). I just reverted back to explicitly giving 3.18.0, and the init phase worked. And then going back to 3.18.1, still works fine. And specifying latest also works fine.
