Hi, I added location data in the TTN console for my different sensors.
Now, I would like to include the individual locations in the uplink message. Is this possible?
I am not sure if I understand you well but: if you look into the json struct that is presented on the uplink of a device with WebSocket or on MQTT, you will find there the location of your device as you administered in the TTN console application.
Many thanks! That was precisely what I was looking for. I was not aware that it was already part of the transmitted information.
Now I would like to do the same with the āEnd device nameā as well defined in the console, but it looks like that it is not part of the transmitted information. Am I overlooking something? Does it make sense to place it as a feature request?
Everything is in the json struct as you can see in this example:
This example is captured in Node_red with MQTT. As you can see the device_id is your End device name
   "topic": "v3/han-demo-test-application@ttn/devices/han-kiss-04/up",
   "payload": {
      "end_device_ids": {
         "device_id": "han-kiss-04",
         "application_ids": {
            "application_id": "han-demo-test-application"
         "dev_eui": "0000000B001F8745",
         "join_eui": "70B3D50000013DED",
         "dev_addr": "260B0000"
            Yes, I am aware of the device-id being part of the information sent, but the āEnd device nameā as defined in āGeneral Settingsā in the console is not. The advantage of using āEnd device nameā would be that it can be changed once the logger has been set up.
You can also query the end device API for additional properties of the device.
API reference is at:
https://www.thethingsindustries.com/docs/reference/api/end_device/
Java code I am using to access the API is at:
But preferably cache the information rather than query on every uplink ā¦
Many thanks. I am able to get the āEnd device nameā with a simple GET request, thatās great, but I struggle to implement it in the uplink payload formatter. I will open another topic on this.
I very much doubt there is anything in that will allow a XHR within the payload formatter or will there ever be. There has already been a compromise on the JS size (an increase) despite people experiencing timeouts on the running of their scripts.
It would be a huge burden on the servers to run each and every time so it would be more likely (but still unlikely to happen) if you got some device & application meta-data provided to the payload formatter.
Thank you for the clear answer.
