Hello there,
I got some issues with the new V3 stack and hope anyone can help me.
Let me start from the beginning:
I have some devices that were connected to V2 over my TBMH100 gateway.
Now I switched to V3 ( no migration ) as I’m still trying to get
the hang of all this stuff.
I added the gateway, all good.
I added the application, all good.
I added the devices, all good.
But after a while the devices stopped working. When I trigger
them ( via a button ) to send their data, I can see in the gateway
log that the data arrives, but without the intended payload. Also
the data is never transmitted to the application. When I delete
the devices and add them as new, they work for a while. I’ve been
in contact with the creator of the devices, it seems like it might
be an issue with the frame counter, as it’s stored in a volatile(?)
memory and is reset when the device is powered off or loses power.
This has never been an issue with V2 since you could set the V2 console to ignore the
frame counter. I did some research but am still unsure about that.
So maybe someone can answer me a few questions:
- Is this correct? Is this issue based on the frame counter?
- Is there a way to reset the frame counter of a device with CLI? ( See below )
- Is there a way to join/rejoin a device with CLI? Since I read that would also reset the frame counter
- Is there another solution to this? The thing is, those devices can not store the frame counter in a
non-volative memory due to hardware limitation.
About resetting the frame counter I found some hints in the forums but they didn’t work. Like:
> ttn-lw-cli end-devices set [app-id] [dev-id] --session.last-f-cnt-up=1 --session.dev_addr="[dev-addr]"
Just throws an error:
WARN Finished unary call {"duration": 0.055, "error": "rpc error: code = Internal desc = error:pkg/rpcserver:rpc_recovered (Internal Server Error)", "error_correlation_id": "41c54a19ec4745f8a935132135ae82a5", "error_name": "rpc_recovered", "error_namespace": "pkg/rpcserver", "grpc.method": "Set", "grpc.service": "ttn.lorawan.v3.NsEndDeviceRegistry", "grpc_code": "Internal", "namespace": "grpc", "request_id": "c197d9db-ec03-47ae-a28e-dc2bb2360cb8"} error:pkg/rpcserver:rpc_recovered (Internal Server Error) correlation_id=41c54a19ec4745f8a935132135ae82a5
The devices are connected with OTAA
This is the data / payload I ( the gateway ) receive when only the gateway receives data:
> "name": "gs.up.receive",
> "time": "2021-08-24T14:42:38.278489636Z",
> "identifiers": [
> "gateway_ids": {
> "gateway_id": "ds-58a0cbffe802852"
> "gateway_ids": {
> "gateway_id": "ds-58a0cbffe802852",
> "eui": "58A0CBFFFE802852"
> "data": {
> "@type": "type.googleapis.com/ttn.lorawan.v3.UplinkMessage",
> "raw_payload": "QJZLCybAAwABeVTduEjSQM3/xOYBSbSzmQ==",
> "payload": {
> "m_hdr": {
> "m_type": "UNCONFIRMED_UP"
> "mic": "SbSzmQ==",
> "mac_payload": {
> "f_hdr": {
> "dev_addr": "260B4B96",
> "f_ctrl": {
> "adr": true,
> "adr_ack_req": true
> "f_cnt": 3
> "f_port": 1,
> "frm_payload": "eVTduEjSQM3/xOYB"
> "settings": {
> "data_rate": {
> "lora": {
> "bandwidth": 125000,
> "spreading_factor": 12
> "coding_rate": "4/5",
> "frequency": "867100000",
> "timestamp": 4024851540,
> "time": "2021-08-24T14:42:38.198283910Z"
> "rx_metadata": [
> "gateway_ids": {
> "time": "2021-08-24T14:42:38.198283910Z",
> "rssi": -94,
> "channel_rssi": -94,
> "snr": 7,
> "uplink_token": "CiAKHgoSZHMtNThhMGNiZmZlODAyODUyEghYoMv//oAoUhDUuJn/DhoMCN6KlIkGEKf0vIQBIKDQ4t6R6QQ="
> "received_at": "2021-08-24T14:42:38.277821991Z",
> "correlation_ids": [
> "gs:conn:01FDVNJS2P8A8KDW5K9Q0C75BZ",
> "gs:uplink:01FDW9SY2616Y6Q38M9S45TBA2"
> "origin": "ip-10-100-5-213.eu-west-1.compute.internal",
> "context": {
> "tenant-id": "CgN0dG4="
> "visibility": {
> "rights": [
> "RIGHT_GATEWAY_TRAFFIC_READ",
> "unique_id": "01FDW9SY26QRJFTNHCBMRQZFE9"
This is the data I ( the application ) receive after I delete the device and add it fully new with new EUI:
> "name": "as.up.data.forward",
> "time": "2021-08-24T15:13:39.703536794Z",
> "identifiers": [
> "device_ids": {
> "device_id": "eui-70b3d57ed00446f5",
> "application_ids": {
> "application_id": "loradetest"
> "device_ids": {
> "dev_eui": "70B3D57ED00446F5",
> "join_eui": "0000000000000000",
> "dev_addr": "260B5356"
> "data": {
> "@type": "type.googleapis.com/ttn.lorawan.v3.ApplicationUp",
> "end_device_ids": {
> "as:up:01FDWBJQVBNX282MJW1QATKDXP",
> "gs:up:host:01FDVNJS373BFEHYESGN5HM1W5",
> "gs:uplink:01FDWBJQMVT9BSPNSK258B5R44",
> "ns:uplink:01FDWBJQMXSC2WHCQGEJ6B1AHV",
> "rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01FDWBJQMWQ7ZSV075WN3GH2ZZ",
> "rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01FDWBJQVA8JZ8JR60Q9VTXYPZ"
> "received_at": "2021-08-24T15:13:39.692753587Z",
> "uplink_message": {
> "session_key_id": "AXt4uUmyW2hX9qxIZ09gIQ==",
> "f_port": 1,
> "frm_payload": "ECoRBBIzAxlUAOcFNVYnBAcACABZAL0=",
> "decoded_payload": {
> "command": 1,
> "reader1": {
> "id": 0,
> "value": 4.2
> "reader10": {
> "id": 9,
> "value": 18.9
> "reader2": {
> "id": 1,
> "value": 0.4
> "reader3": {
> "id": 2,
> "value": 5.1
> "reader4": {
> "id": 3,
> "value": 25
> "reader5": {
> "id": 4,
> "value": 23.1
> "reader6": {
> "id": 5,
> "value": 53
> "reader7": {
> "id": 6,
> "value": 998.8
> "reader8": {
> "id": 7,
> "value": 0
> "reader9": {
> "id": 8,
> "value": 0
> "sensorcount": 10
> "rx_metadata": [
> "gateway_ids": {
> "time": "2021-08-24T15:13:39.416470050Z",
> "timestamp": 1591138891,
> "rssi": -84,
> "channel_rssi": -84,
> "snr": 9.75,
> "uplink_token": "CiAKHgoSZHMtNThhMGNiZmZlODAyODUyEghYoMv//oAoUhDLtNv2BRoMCKOZlIkGELLm1uYBIPjpkrqnnwU="
> "settings": {
> "data_rate": {
> "lora": {
> "spreading_factor": 7
> "data_rate_index": 5,
> "frequency": "868100000",
> "received_at": "2021-08-24T15:13:39.485111933Z",
> "consumed_airtime": "0.077056s",
> "network_ids": {
> "net_id": "000013",
> "tenant_id": "ttn",
> "cluster_id": "ttn-eu1"
> "origin": "ip-10-100-15-175.eu-west-1.compute.internal",
> "context": {
> "visibility": {
> "rights": [
> "RIGHT_APPLICATION_TRAFFIC_READ",
> "unique_id": "01FDWBJQVQP8TMTPFV9KTSDK91"
Many thanks to everyone who can help with this. Please tell me if I can provide any more info.
Also, sorry for the formatting, I really tried my best.
