I could get my hands on a “PNI PlacePod” parking sensor and I’m trying to get it working with TTN. I added an application as well as a device. Since I can’t change the data the device is sending, I changed the device EUI and the application EUI in my application to the data the sensor sends.
When I look at the gateway traffic, I can see a join request sent by the device. DEV EUI and App EUI are the same as the ones I used in the application. But for some reason, the join request does not work and I don’t know, what I did wrong.
The DEV EUI is 008000000400884E and I chose ABP for acitvation. Does anyone have a hint about what I am doing wrong?
Regards from Cologne
Uwe
sure… the one I posted yesterday.
did you contact the seller and what was his reaction ?
I see they have a german sales representative in your City
yepp… that’s the one. I contacted the German reseller unitronic. They don’t have any experience with TTN yet. By now, they only used the PNI-infrastructure at PNI Cloud - I’d rather get it working with TTN.
I just received the infromation, that there still is an activation tool missing. Maybe that will solve the problem, but I actually don’t think so.
the sensor (node) probably only responds to their infrastructure @ this moment.
don’t think it’s open source
- but would be very nice to get it working on TTN !
could you provide the adress of the reseller here or by pm: lorawan.berlin@gmail.com
there are some ideas… growing
thank you
g.
Hi @mascarpone,
did you get any information in the meantime? I don’t find any details at https://www.pnicorp.com/placepod/ regarding TTN Support. Also Unitronic sent us an offer with their own Gateways.
Hi @gregorwolf,
yes, the placepod works with TTN. A few days ago I received an offer from unitronic to swap our placepod for a new version with a new firmware. As far as I understood the new version, it should be even easier to register the device to TTN and the protocol will be easier to understand.
Hi @gregorwolf,
today I received the updated placepod with the new firmware. It is really easy now to integrate the device to TTN. There is an iOS-App by which you can reconfigure the device (including App EUI and App Key) via BLE.
Also, the new communication protocol based on #lora-cayenn-low-power-payload is easier to understand and to handle. I will have to re-write the decoder, but it should be easier then before.
Thank you @mascarpone for the follow up. We’ve not yet decided on our hardware. So it’s good to know.
some pics from the setup procedure to TTN would be very welcome
Is there a decoder for the PNI Placepod ?
Hello
I’m looking for a codec ready to use for PNI PLACEPODS?
Does somebody have this
erm, what does the supplier or distributor offer? have you asked? what does their documentation call out?
Supplier provides a technical doc explaining how to decode manually the data
But Finally, choosing CAYENNE LPP standard codec, it works fine
