Any support questions you might have can be asked here:
https://www.thethingsnetwork.org/marketplace/product/placepod
I am trying to connect a sensor to TheThingsStack server. Unfortunately, I have not been able to receive any data so far. I’m using Milesight UG65-L04EU-868M-EA gateway.
In the specification I have not found any information about e.g. LoRaWAN version or regional parameters of the sensor, so I would like to make sure if my configuration shown below is correct.
AppEUI: from label
DevEUI: SN from label
AppKey: from label
Frequency plan: Europe 863-870 MHz (SF9 for RX2 - recommended)
LoRaWAN version: 1.0.2
Regional parameters 1.0.2 revision B
Payload formatter: CayenneLPP
As for the gateway configuration, I think it is correct – other (three) devices communicate with it and display correctly in TTS.
On the gateway I set packet forwarder to server eu1.cloud.thethings.network, port 1700.
Any suggestions why PlacePod is not sending any frames or I cannot receive them?
