I think you need to separate the process in order to help debugging, look at your encode (on the device) and decode function (console payload formats) - there is lots of support on forum already, once you see your decoded data is visible in the console app then move onto Node Red.
Then take a look at the recent Node Red support posts on the forum, in particular the one from @arjanvanb and the great example posted, you can import the entire node setup and have running in seconds.
There are loads of examples on this forum honest, below is a thread to start with - once you have the console app data showing your decoded data then you know you can move on to Node Red via MQTT,
Remember the key goal here is to take raw data values (from sensors? maybe temp -2.68c) perhaps signed, decimal, or even simple true/false conditions and convert to values that can be sent via the uplink. These need to be sent efficiently as hex bytes (smallest number possible), this is the encoding process done on the device - likewise the app in the console is where you can do your decoding back to real world values.
