From time to time (once very 4-5 uplinks received), the payload is missing in the uplink messages that my nodes are sending to TTN console.
I noticed that when the upload is missing, the uplink message doesn’t include the frame port f_port. Below is a copy of one uplink with missing upload and one with payload included.
Is there an explanation for this and a fix to avoid that ?
Thanks much !
Example of an uplink with missing upload:
  "name": "as.up.data.forward",
  "time": "2023-01-05T16:20:10.454995553Z",
  "identifiers": [
      "device_ids": {
        "device_id": "hso-scale02",
        "application_ids": {
          "application_id": "ardbeescale-af01"
        "dev_eui": "70B3D57ED0051F21",
        "join_eui": "0000000000000000",
        "dev_addr": "260B40CC"
  "data": {
    "@type": "type.googleapis.com/ttn.lorawan.v3.ApplicationUp",
    "end_device_ids": {
    "correlation_ids": [
      "as:up:01GP1BQ62H7QZAT23PAXX4KJKP",
      "gs:conn:01GP12KEWDFMDE1XFSYADSBHC4",
      "gs:up:host:01GP12KEWK3C53CM5KTP7XQPH8",
      "gs:uplink:01GP1BQ5W0H5J1FHQ824GVVK3B",
      "ns:uplink:01GP1BQ5W1YMH9WBT6ETDR3Q0V",
      "rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01GP1BQ5W17KB5QQ5EX7Y2E8TM",
      "rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01GP1BQ62GHRX5QM2MRW8181NC"
    "received_at": "2023-01-05T16:20:10.448777374Z",
    "uplink_message": {
      "session_key_id": "AYV87/4xiG5e5LbzyR8ZRw==",
      "f_cnt": 109,
      "rx_metadata": [
          "gateway_ids": {
            "gateway_id": "ttig-hso1",
            "eui": "58A0CBFFFE802B8B"
          "time": "2023-01-05T16:20:10.171525955Z",
          "timestamp": 967737180,
          "rssi": -43,
          "channel_rssi": -43,
          "snr": 9,
          "location": {
            "latitude": 45.24887845795117,
            "longitude": 5.825484395027161,
            "altitude": 380,
            "source": "SOURCE_REGISTRY"
          "uplink_token": "ChcKFQoJdHRpZy1oc28xEghYoMv//oArixDc/rnNAxoLCLrx250GEMDNxnIg4P6FjZWWAg==",
          "received_at": "2023-01-05T16:20:10.200606405Z"
      "settings": {
        "data_rate": {
          "lora": {
            "bandwidth": 125000,
            "spreading_factor": 7,
            "coding_rate": "4/5"
        "frequency": "867700000",
      "received_at": "2023-01-05T16:20:10.241305168Z",
      "consumed_airtime": "0.046336s",
      "network_ids": {
        "net_id": "000013",
        "tenant_id": "ttn",
        "cluster_id": "eu1",
        "cluster_address": "eu1.cloud.thethings.network"
  "origin": "ip-10-100-5-128.eu-west-1.compute.internal",
  "context": {
    "tenant-id": "CgN0dG4="
  "visibility": {
    "rights": [
  "unique_id": "01GP1BQ62PCX0JQ5G7PSKWE86X"
Exemple of a complete upload as it should always be:
  "time": "2023-01-05T16:05:03.455826439Z",
  "identifiers": [
      "device_ids": {
  "data": {
    "end_device_ids": {
      "as:up:01GP1AVGAV9BZNZB0Z85HTVBRX",
      "gs:uplink:01GP1AVG4EZ73D9DNATFBGHWBA",
      "ns:uplink:01GP1AVG4E3RYRWZR21CGG9PQE",
      "rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01GP1AVG4EQVTG16BV9JXZDRM4",
      "rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01GP1AVGAT555B7SJRB8WYJAY3"
    "received_at": "2023-01-05T16:05:03.451087768Z",
    "uplink_message": {
      "f_port": 10,
      "f_cnt": 108,
      "frm_payload": "BQD5bDxSVQAC",
      "decoded_payload": {
        "humidity": 60,
        "internalTemp": 15.2,
        "lastDownlink": 0,
        "pressure": 982,
        "temperature": 15.53955078125,
        "voltage": 3.4,
        "weight": 10
      "rx_metadata": [
          "gateway_ids": {
          "time": "2023-01-05T16:05:03.178865909Z",
          "timestamp": 60748692,
          "rssi": -46,
          "channel_rssi": -46,
          "snr": 7.5,
          "location": {
            "altitude": 380,
          "uplink_token": "ChcKFQoJdHRpZy1oc28xEghYoMv//oArixCU5/scGgsIr+rbnQYQ7ZGZdSCg9J2n4vsB",
          "received_at": "2023-01-05T16:05:03.206152946Z"
      "settings": {
        "data_rate": {
          "lora": {
        "frequency": "867500000",
      "received_at": "2023-01-05T16:05:03.246683098Z",
      "consumed_airtime": "0.056576s",
      "network_ids": {
        "net_id": "000013",
        "tenant_id": "ttn",
  "context": {
  "visibility": {
    "rights": [
  "unique_id": "01GP1AVGAZQHFPF9S3Y469EM7S"
