I need to send data to Wattics in this format
{ “id”: “uniqueMeterId”, “tsISO8601”: “2019-06-02T00:00:00.000+00:00”, “value” }
But from things Network the uplink also contains this
“f_port”: 6,
“frm_payload”: “AA==”,
“decoded_payload”: {
“Current”: 0
“rx_metadata”: [
“gateway_ids”: {
“gateway_id”: “test”
“rssi”: 42,
“channel_rssi”: 42,
“snr”: 4.2
“settings”: {
“data_rate”: {
“lora”: {
“bandwidth”: 125000,
“spreading_factor”: 7
Because of which the Wattics server throws an error.
I do not want the rx metadata and the settings to be uplinked and I have no control on this at the payload formatter option.
Right now I am getting the data on AWS and applying this code, to get the data in the format that Wattics accepts,
function getBody(body) {
var data = {};
data.id = body.end_device_ids.device_id;
data.tsISO8601 =new Date(body.received_at).toISOString();
// data.aP_1 = 1000.0;
//data.pC_1 = 2000.0;
data.value=body.uplink_message.decoded_payload.Current;
return data;
But this is not viable since I have to pay for the AWS along with all other requirements.
Can you please suggest a solution that will send data directly from Things Network to Wattics Cloud.
On Wattics side there is no way to include a decoder.
