Parking Sensor available
Is there any magnetic parking sensor with battery and TTN 868Mhz for europe available?
There is one available from Turbo which is 868Mhz - user manual
Besides this, there is also one from Libelium but haven’t heard from anyone successfully connecting to TTN yet.
TBS-220 is compatible to TTN? How can the addresses/keys be configured?
I am not sure if it is compatible with TTN. Best would be to reach out to Turbo directly so they can assist you with this.
Regarding to other topic here and guide it doesn’t look so…
We use these parking sensors (Turbo TBS-220) on TTN with the AS923 band plan. Yes, they are compatible.
There is one here also http://www.iemgroup.com/solutions-products/sensors/presto-sense/
Hi Andrew,
could you share the way to register these TBS220 with TTN ?
many thanks in advance
Once you have the AppEUI/AppKey from your supplier, register just like any other OTAA device.
I have the AppEUI/AppKey but to register devices into my application I can only edit devEUI and use generated values by new ttn application. Where should I go to be able to enter theses informations ?
I finally found the right place to enter my informations !
So sorry for the inconvenience :wink:
best regards
How can it be configured? USB/Serial?
Looking for a seller where the required number of parking sensors is less than 10.
I need them for a pilot and I don’t need 50, 100 or more of them. Any suggestions?
and be carefull… not all parking sensors work with TTN
I needed two sensors. Was not possible to find a dealer.
Hi Maj
How did you get all the informations about the device?
A friend gave me a Turbo TBS-220, but he gave me only the dev eui (sticker under the sensor).
Is there a way to read it out from the sensor?
Or how did you connect the sensor with ttn?
Or ist the only way to the appkey through the supplier?
Many thanks
Hi thomaswa
I bought one for testing from PNI. But not directly, i ordered it from the european distributor - Unitronic.
https://www.unitronic.de.
It was very simple and a few days later came the delivery.
Hi TTN-South
Thank you for the information.
Contact to Unitronic was very friendly and will get mine in a few days.
Do you have any information about decoder for TTN?
Do you have experience regarding possible distance sensor<->gateway?
thanks
Thomas
Data format is Cayenne LPP.
