We are using B-L072Z-LRWAN1 Discovery board,
Packet loss very high we only getting node info at the gateway but not getting data packet.
You will need to be clearer about what exactly you mean.
Are you receiving packets at the gateway? If so, how are you sure they are from this node? Have you manually verified the device address? Are they regular data packets, or OTAA join requests?
If you see packets at the gateway, but not decoded application side, you should check to make sure the keys used by the node accurately match those registered in the server.
You should not create multiple threads about the same problem.
And if you want help, you’ll need to answer the question that was asked (though put the answer over there)
