OTAA Join with Adafruit feather M0 LoraWan
I am trying to connect a Adafruit feather M0 LoraWan to a Sentrius RG1xx via OTAA without success, the the ABP version works instead.
I already tried different suggestions found online and inside this forum with no luck.
Here is the code I am using.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <SRSPacket.h>
#include <ArduinoUniqueID.h>
bool connected = true;
static const u1_t PROGMEM APPEUI[8] = { 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA };
void os_getArtEui (u1_t* buf) {
  memcpy_P(buf, APPEUI, 8);
static const u1_t PROGMEM DEVEUI[8] = { 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA };
void os_getDevEui (u1_t* buf) {
  memcpy_P(buf, DEVEUI, 8);
static const u1_t PROGMEM APPKEY[16] = {0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA};
void os_getDevKey (u1_t* buf) {
  memcpy_P(buf, APPKEY, 16);
static osjob_t sendjob;
const unsigned TX_INTERVAL = 60;
  .nss = 8, // PA06
  .rxtx = LMIC_UNUSED_PIN,
  .rst = 4,
  .dio = {3, 6, LMIC_UNUSED_PIN},
  .rxtx_rx_active = 0,
  .rssi_cal = 8,              // LBT cal for the Adafruit Feather M0 LoRa, in dB
  .spi_freq = 8000000,
void onEvent (ev_t ev) {
  Serial.print(os_getTime());
  Serial.print(": ");
  switch (ev) {
    case EV_SCAN_TIMEOUT:
      break;
    case EV_BEACON_FOUND:
      break;
    case EV_BEACON_MISSED:
      break;
    case EV_BEACON_TRACKED:
      break;
    case EV_JOINING:
      break;
    case EV_JOINED:
        connected = true;
        u4_t netid = 0;
        devaddr_t devaddr = 0;
        u1_t nwkKey[16];
        u1_t artKey[16];
        Serial.print("netid: ");
        Serial.println(netid, DEC);
        Serial.print("devaddr: ");
        Serial.println(devaddr, HEX);
        Serial.print("artKey: ");
        for (size_t i = 0; i < sizeof(artKey); ++i) {
          if (i != 0)
            Serial.print("-");
          Serial.print(artKey[i], HEX);
        Serial.println("");
        Serial.print("nwkKey: ");
        for (size_t i = 0; i < sizeof(nwkKey); ++i) {
          if (i != 0)
            Serial.print("-");
          Serial.print(nwkKey[i], HEX);
        Serial.println("");
      LMIC_setLinkCheckMode(0);
      break;
    case EV_JOIN_FAILED:
      break;
    case EV_REJOIN_FAILED:
      break;
    case EV_TXCOMPLETE:
      digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
      if (LMIC.dataLen) {
        Serial.println(LMIC.dataLen);
      os_setTimedCallback(&sendjob, os_getTime() + sec2osticks(TX_INTERVAL), do_send);
      break;
    case EV_LOST_TSYNC:
      break;
    case EV_RESET:
      break;
    case EV_RXCOMPLETE:
      // data received in ping slot
      break;
    case EV_LINK_DEAD:
      break;
    case EV_LINK_ALIVE:
      break;
    case EV_TXSTART:
      if (firstTime) {
        connected = false;
        firstTime = false;
      break;
    default:
      break;
   convert ADC value to microvolt
   ADV range 0 1.65
   ADC resolution = 4096
   each unit correspond to 403 uV 1650000/4096
int adc2Microvolt(int adcValue)
  return adcValue * 403;
void
printADCValue(char *label, int value)
  int uV = adc2Microvolt(value);
  Serial.print(label);
  Serial.print(value, DEC);
  Serial.print("(Dec) ");
  Serial.print(value, HEX);
  Serial.print("(Hex) ");
  Serial.print(value, BIN);
  Serial.print("(Bin) ");
  Serial.print(uV, DEC);
  Serial.println("(uV) ");
void do_send(osjob_t* j) {
  } else {
    LMIC_setTxData2(1, mydata, sizeof(mydata) - 1, 0);
void(* RebootSW)(void) = 0;
void setup() {
  osjob_t initjob;
  delay(1000);
  while (! Serial);
  Serial.begin(115200);
  firstTime = true;
  os_init();
  LMIC_reset();
  LMIC_setClockError(MAX_CLOCK_ERROR * 10 / 100);
  LMIC.dn2Dr = SF9;
  LMIC_setDrTxpow(DR_SF12,14);
  do_send(&sendjob);
  delay(5000);
  //LMIC_startJoining();
void loop() {
  os_runloop_once();
The serial output looks like this
12:31:54.718 → Starting
12:31:54.752 → Packet queued
12:31:59.749 → 398917: EV_JOINING
12:32:06.899 → 846772: EV_TXSTART
12:33:12.271 → 4935503: EV_TXSTART
12:34:22.099 → 9302670: EV_TXSTART
12:35:35.236 → 13875239: EV_TXSTART
12:37:44.651 → 21970289: EV_TXSTART
12:39:50.922 → 29867053: EV_TXSTART
12:41:51.919 → 37433584: EV_TXSTART
12:45:44.605 → 51987602: EV_TXSTART
12:49:29.507 → 66052911: EV_TXSTART
I have no real idea why every minute this code sends a new message to the gateway that is seen as a new join reequest.
Do you have any suggestions?
Thanks in advance.
Do you see join request activity in the application data page? Is the node listed ‘active’ in the node overview?
If the answer to both questions is no you need to check your EUIs and key. Byte ordering is frequently the issue.
BTW, you node joins/connects to the network, not a gateway.
The node is active in the application page, and it also see join requests but it does not answer to them as far as I can see.
And you are right about the network/gateway, it was my bad.
