OTAA Join Start... joined failed
Hi
my gateway is configured in thethingsnetwork. i have add application tracker RACK7200
but this application not send data
request my tracker by rack seriel port tool
at+get_config=lora:status
OK Work Mode: LoRaWAN
Region: EU868
Send_interval: 30s
Auto send status: true.
Send_interval work at sleep
Join_mode: OTAA
DevEui: DECEECFEAC8BE466
AppEui: 70B3D57ED0038835
AppKey: AC1F09FFFE003576AC1F09FFF8687200
Class: A
Joined Network:false
IsConfirm: unconfirm
AdrEnable: true
EnableRepeaterSupport: false
RX2_CHANNEL_FREQUENCY: 869525000, RX2_CHANNEL_DR:0
RX_WINDOW_DURATION: 3000ms
RECEIVE_DELAY_1: 1000ms
RECEIVE_DELAY_2: 2000ms
JOIN_ACCEPT_DELAY_1: 5000ms
JOIN_ACCEPT_DELAY_2: 6000ms
Current Datarate: 0
Primeval Datarate: 5
ChannelsTxPower: 0
UpLinkCounter: 0
DownLinkCounter: 0
[LoRa]:Joined Failed!
OK Sleep
in application thethingsnetwork
Status
never seen
Frames up
0reset frame counters
Frames down
0
you know thie issue ??
tkx
First check if your gateway locally (or via ttn console) reports raw transmissions potentially related to these join requests.
Did you actually register your device with TTN?
yes
return command status Lora
Wake up .
GPS Init OK
OTAA Join Start…
Region: EU868
Send_interval: 30s
Join_mode: OTAA
Class: A
AdrEnable: true
Current Datarate: 5
ChannelsTxPower: 0
UpLinkCounter: 0
DownLinkCounter: 0
Hello
it works
Okay
FAIL The satellite signal cannot be found!
Battery voltage = 3.830 V
Acceleration (g) of X, Y, Z:
1.02,0.02,0.02
Gyro (degress / s) of X, Y, Z:
0.44.0.92.0.29
Magnetometer (uT) of X, Y, Z:
-44.70, -11.70, -67.20
LoRa: Cancel confirmation of sending data OK
but why did I receive the msg
The RAK7200 doesn’t find GNSS (GPS, Glonass…) signals, that’s the reason for the “FAIL”.
Can you choose either this or the RAK forum - double posting causes all sorts of confusion.
I think Nikola’s response is probably the best course of action.
Hi @descartes the problem persists.
I believe my antenna and connector maybe not correct
I tested with different wait times over 100 but no improvement.
I am waiting for a new connector and a new antenna
Do you use an active GNSS-antenna? If you do, make sure that the powersupply for the antenna is switched “ON”
The RAK7200 is an all-in-one unit.
@envxcom, I post as nmcc on the RAK forum - I’ll be answering there, duplication of effort isn’t a good use of volunteers time and RAK are the subject matter expert on the RAK7200 …
