I am not able to get traffic data on TTN gateway page. I am using OTAA method of activation and LG-01 N dragino gateway. I am getting output in the serial monitor of Arduino IDE but not able to see any traffic on ttn gateway page. I am using US frequency of 915 MHz as I am in California right now and the server address as ttn-router-us-west. Any help or suggestions are welcomed and recommended. Thank you in advance.
Sorry to disappoint but that is not a LoRaWAN compliant gateway and it should not be used with TTN. Using it will cause issues for you (as you noticed) and other TTN users near you. Please remove the TTN configuration from the device and use that hardware as the Lora gateway which it is.
A suitable gateway for TTN would be the Dragino LPS 8. (There are other choices as well)
