Node-Red upgrade TTN V2 to V3
I made this small guide if someone has issue with moving the integration in Node-Red for TTN Devices V2 to V3
It allows V2 and V3 devices to run in parallel and point to the same Influx DB
would appreciate your comments
I updated and simplified the flow, no need for a dedicated JSON node, the MQTT node can render as parsed JSON object directly.
