I have recently started working on LMIC library and it was working fine so far, now I am facing a serious issue. I have ABP node which starts off working fine. The node captures magnetometer data and sends to a gateway on a 30-second interval. The code can be found here < https://github.com/akshaim/LoRaNode_Arduino/tree/master/LoRa_865_Battery >
The node fails to send data after around 200 packets and LMIC Debug data show “uplink delayed until …” error. Last few lines of debug log(along with comments) is attached for reference. Any help is deeply appreciated.
[17:49:12.962350 25.631989] Sleep complete //node wakes up from sleep
[17:49:12.978556 0.016206] a_xy228 a_xz233 a_yz229
[17:49:13.009979 0.031424] Enter do_send
[17:49:13.025927 0.015948] 347136201: engineUpdate, opmode=0x908
[17:49:13.058001 0.032074] 347137705: Uplink data pending
[17:49:13.090223 0.032222] 347139720: Considering band 0, which is available at 388
[17:49:13.153837 0.063614] 347143426: Considering band 3, which is available at 0
[17:49:13.201948 0.048111] 347147009: No channel found in band 3
[17:49:13.249569 0.047618] 347149470: Considering band 0, which is available at 388
[17:49:13.313015 0.063448] 347153184: No channel found in band 0
[17:49:13.345306 0.032292] 347155645: Considering band 1, which is available at 345710800
[17:49:13.409153 0.063846] 347159740: Considering band 2, which is available at 388
[17:49:13.472689 0.063538] 347163454: No channel found in band 2
[17:49:13.504812 0.032122] 347165915: Considering band 1, which is available at 345710800
[17:49:13.568289 0.063478] 347170019: No channel found in band 1
[17:49:13.616145 0.047856] 347172479: Airtime available at 345710800 (channel duty limit)
[17:49:13.679799 0.063653] 347176574: Airtime available at 345818595 (global duty limit)
[17:49:13.743777 0.063979] 347180604: Ready for uplink
[17:49:13.775581 0.031803] 347183211: Updating info for TX at 347137704, airtime will be 3536. Setting available time for band 1 to 1273495552
[17:49:13.887426 0.111845] 347190039: TXMODE, freq=865062500, len=21, SF=7, BW=125, CR=4/5, IH=0
[17:49:13.966923 0.079497] 347190036: irq: dio: 0x0 flags: 0x8
[17:49:13.999007 0.032085] 347192387: Scheduled job 0x2ea, cb 0x240e ASAP
[17:49:14.046888 0.047880] Packet queued
[17:49:14.062758 0.015870] Leave do_send
[17:49:14.078713 0.015956] 347197382: Running job 0x2ea, cb 0x240e, deadline 0
[17:49:14.142103 0.063389] 347200766: Scheduled job 0x2ea, cb 0x2421 at 347252505
[17:49:14.907146 0.765042] 347252511: Running job 0x2ea, cb 0x2421, deadline 347252505
[17:49:14.955563 0.048417] 347252684: RXMODE_SINGLE, freq=865062500, SF=7, BW=125, CR=4/5, IH=0
[17:49:15.034720 0.079158] 347252851: irq: dio: 0x1 flags: 0x80
[17:49:15.067107 0.032386] 347255267: Scheduled job 0x2ea, cb 0x2429 ASAP
[17:49:15.114876 0.047770] 347258313: Running job 0x2ea, cb 0x2429, deadline 0
[17:49:15.178321 0.063445] 347261696: Scheduled job 0x2ea, cb 0x2440 at 347317981
[17:49:16.007143 0.828822] 347317987: Running job 0x2ea, cb 0x2440, deadline 347317981
[17:49:16.071155 0.064012] 347318161: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
[17:49:16.182312 0.111156] 347324454: irq: dio: 0x1 flags: 0x80
[17:49:16.214699 0.032388] 347324538: Scheduled job 0x2ea, cb 0x2396 ASAP
[17:49:16.262575 0.047875] 347325715: Running job 0x2ea, cb 0x2396, deadline 0
[17:49:16.310673 0.048099] Enter onEvent
[17:49:16.326525 0.015852] EV_TXCOMPLETE (includes waiting for RX windows) // successful transmission
[17:49:16.389758 0.063233] Leave onEvent
[17:49:16.405718 0.015960] 347334226: engineUpdate, opmode=0x900
[17:49:16.437840 0.032122] Enter sleeping for 3 cycles of 8 seconds
[17:49:42.069730 25.631889] Sleep complete
[17:49:42.086105 0.016376] a_xy228 a_xz233 a_yz229
[17:49:42.117703 0.031598] Enter do_send
[17:49:42.133661 0.015958] 348916902: engineUpdate, opmode=0x908
[17:49:42.165775 0.032114] 348918406: Uplink data pending
[17:49:42.197666 0.031891] 348920421: Considering band 1, which is available at 347491304
[17:49:42.261485 0.063819] 348924516: Considering band 2, which is available at 388
[17:49:42.325137 0.063651] 348928221: Considering band 3, which is available at 0
[17:49:42.388628 0.063492] 348931804: No channel found in band 3
[17:49:42.420754 0.032126] 348934266: Considering band 1, which is available at 347491304
[17:49:42.484632 0.063877] 348938361: Considering band 2, which is available at 388
[17:49:42.548213 0.063582] 348942074: No channel found in band 2
[17:49:42.580477 0.032263] 348944536: Considering band 1, which is available at 347491304
[17:49:42.659480 0.079004] 348948640: No channel found in band 1
[17:49:42.691620 0.032139] 348951110: No channel found in band 0
[17:49:42.723945 0.032326] 348953570: Airtime available at 2148918405 (channel duty limit)
[17:49:42.803013 0.079067] 348957730: Uplink delayed until 2148918405 //Error !!!
[17:49:42.835500 0.032488] 348960530: Scheduled job 0x2ea, cb 0x473 at 2148918280
[17:49:42.898912 0.063412] Packet queued
[17:49:42.914871 0.015959] Leave do_send
