Recently flew from Birmingham UK to Corfu - with a Lorawan GPS tracker attached to hand luggage.
No GPS lock - but an incredible amount of gateways picked up the transmission during the flight all over Europe.
Is there anyway of searching against Gateway EUI?
kersing
(Jac Kersing)
May 26, 2019, 8:23pm
2
Is it legal to have transmitting devices with an active gps inside a flying plane these days??? It seems times have changed…
Not sure.
Did security question you about the device ?
pe1mew
(Remko)
May 27, 2019, 5:27am
5
I have a lot of electronics with me always and I only get questions incidentally. Also restricins have reduced a lot on the use of electronics on board. Think of all the smartfones that stay on on purpose or “forgotten”.
From regulator point of view it is not planned for. Devices using ISM bands are intended to be used at a average night of 1,5 meters above ground.
Maybe, but in the UK; "Equipment may be used airborne’
schulti
(Stefan)
May 27, 2019, 5:36am
7
Look at ttnctl for batch queries about Gateway indentities:
ttnctl gateway info eui-abc123def456
No questions. Was attached externally on hand luggage. Small Zane device.
Here is the data from the 3 hours flight of Gateways which received data. There is a huge hit of multiple gateways at one point! UK > Corfu
EUI
Date
SF
RSSI
SNR
Port
FCNT
GW EUI
Payload
0006110090301007
2019-05-25 17:47:14
SF12
-120
-18.80
205
3350
00-80-00-00-A0-00-65-7A
032823
0006110090301007
2019-05-25 17:42:36
SF12
-121
-13.80
205
3349
00-00-02-4B-76-03-0E-96
032623
0006110090301007
2019-05-25 17:42:36
SF12
-120
-14.20
205
3349
00-00-02-4B-76-03-0F-85
032623
0006110090301007
2019-05-25 17:42:36
SF12
-123
-15.00
205
3349
00-80-00-00-00-00-9D-62
032623
0006110090301007
2019-05-25 17:42:36
SF12
-121
-14.50
205
3349
00-00-02-4B-76-03-0F-67
032623
0006110090301007
2019-05-25 17:37:58
SF12
-120
-14.20
205
3348
00-00-02-4B-76-03-0F-66
032523
0006110090301007
2019-05-25 17:37:58
SF12
-120
-16.80
205
3348
00-00-02-4B-76-03-0F-77
032523
0006110090301007
2019-05-25 17:19:52
SF12
-121
-18.80
205
3344
AA-55-5A-00-00-09-20-82-22
031824
0006110090301007
2019-05-25 17:19:52
SF12
-135
-22.00
205
3344
72-76-FF-00-2E-06-27-EF
031824
0006110090301007
2019-05-25 17:15:12
SF12
-121
-16.75
205
3343
AA-99-AA-BB-CC-DD-EE-FF
031525
0006110090301007
2019-05-25 17:15:12
SF12
-120
-17.50
205
3343
00-00-02-4B-08-03-01-86
031525
0006110090301007
2019-05-25 17:15:12
SF12
-134
-20.00
205
3343
00-72-76-FF-00-2E-06-29-77
031525
0006110090301007
2019-05-25 17:15:12
SF12
-135
-21.00
205
3343
031525
0006110090301007
2019-05-25 17:15:12
SF12
-135
-22.00
205
3343
72-76-FF-00-00-06-2E-94
031525
0006110090301007
2019-05-25 17:15:12
SF12
-136
-22.00
205
3343
031525
0006110090301007
2019-05-25 17:10:34
SF12
-121
-19.00
205
3342
00-00-02-4B-08-0E-08-5B
031025
0006110090301007
2019-05-25 16:38:28
SF12
-121
-17.00
205
3341
00-00-02-4B-76-03-02-0E
032825
0006110090301007
2019-05-25 16:38:28
SF12
-125
-18.80
205
3341
AA-55-5A-00-76-03-14-A0
032825
0006110090301007
2019-05-25 16:33:49
SF12
-118
-15.20
205
3340
B8-27-EB-FF-FE-C2-FA-BB
032625
0006110090301007
2019-05-25 16:33:49
SF12
-123
-16.50
205
3340
B8-27-EB-FF-FE-3D-69-68
032625
0006110090301007
2019-05-18 10:46:29
SF12
-119
-14.20
205
2807
00-00-00-02-4B-76-03-0D-0D-B0
030645
0006110090301007
2019-05-18 10:46:29
SF12
-117
-16.20
205
2807
B8-27-EB-FF-FE-5B-CA-3E
030645
system
(system)
Closed
July 26, 2019, 3:48pm
10
