My gateways are very far away from my nodes - everything is setup in a remote area. On V2 I was disabling ADR and setting my nodes to use SF9/BW125, which worked perfectly. I’ve updated my gateways to V3 and I can no longer get them to receive packets from my nodes when ADR is disabled and I use SF9/BW125.
If I enable ADR on my nodes, it does work but then 90% of the sent packets never get received since it uses SF7. After hours and hours my nodes never switch to a different spreading factor, so I really would just like to be able to disable ADR like before.
Any idea why this no longer works?
