No JoinAccept with my Heltec Lora V2
I use the Heltec Lora V2 with LMiC and the following code in the EU.
// 0x70.
static const u1_t PROGMEM APPEUI[8] = { 0x15, 0x44, ..., 0x84, 0xEA };
void os_getArtEui(u1_t* buf){ memcpy_P(buf, APPEUI, 8); }
static const u1_t PROGMEM DEVEUI[8] = { 0x2C, 0x4F, ..., 0x70, 0x00 };
void os_getDevEui(u1_t* buf){ memcpy_P(buf, DEVEUI, 8); }
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] = { 0x14, 0x5B, ..., 0xDD };
void os_getDevKey(u1_t* buf){ memcpy_P(buf, APPKEY, 16); }
static uint8_t Payload[] = "Hello, world!";
static osjob_t TransmitJob;
  .nss = 18,
  .rxtx = LMIC_UNUSED_PIN,
  .rst = 14,
  .dio = {26, 35, 34},
const uint8_t TX_INTERVAL       = 60;
void Transmit(osjob_t* Job);
void printHex2(unsigned v) {
    v &= 0xff;
    if (v < 16)
        Serial.print('0');
    Serial.print(v, HEX);
void onEvent(ev_t Event)
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(Event)
        case EV_SCAN_TIMEOUT:
            Serial.println("EV_SCAN_TIMEOUT");
            break;
        case EV_BEACON_FOUND:
            Serial.println("EV_BEACON_FOUND");
            break;
        case EV_BEACON_MISSED:
            Serial.println("EV_BEACON_MISSED");
            break;
        case EV_BEACON_TRACKED:
            Serial.println("EV_BEACON_TRACKED");
            break;
        case EV_JOINING:
            Serial.println("EV_JOINING");
            break;
        case EV_JOINED:
            Serial.println("EV_JOINED");
                u4_t netid = 0;
                devaddr_t devaddr = 0;
                u1_t nwkKey[16];
                u1_t artKey[16];
                Serial.print("netid: ");
                Serial.println(netid, DEC);
                Serial.print("devaddr: ");
                Serial.println(devaddr, HEX);
                Serial.print("AppSKey: ");
                for(size_t i = 0; i < sizeof(artKey); ++i)
                    if(i != 0)
                        Serial.print("-");
                        printHex2(artKey[i]);
                Serial.println("");
                Serial.print("NwkSKey: ");
                for (size_t i = 0; i < sizeof(nwkKey); ++i)
                    if(i != 0)
                        Serial.print("-");
                    printHex2(nwkKey[i]);
                Serial.println();
            LMIC_setLinkCheckMode(0);
            break;
        || case EV_RFU1:
        ||     Serial.println(F("EV_RFU1"));
        ||     break;
        case EV_JOIN_FAILED:
            Serial.println("EV_JOIN_FAILED");
            break;
        case EV_REJOIN_FAILED:
            Serial.println("EV_REJOIN_FAILED");
            break;
        case EV_TXCOMPLETE:
            Serial.println("EV_TXCOMPLETE (includes waiting for RX windows)");
            if(LMIC.txrxFlags & TXRX_ACK)
                Serial.println("Received ack");
            if(LMIC.dataLen)
                Serial.print("Received ");
                Serial.print(LMIC.dataLen);
                Serial.println(" bytes of payload");
            os_setTimedCallback(&TransmitJob, os_getTime() + sec2osticks(TX_INTERVAL), Transmit);
            break;
        case EV_LOST_TSYNC:
            Serial.println("EV_LOST_TSYNC");
            break;
        case EV_RESET:
            Serial.println("EV_RESET");
            break;
        case EV_RXCOMPLETE:
            Serial.println("EV_RXCOMPLETE");
            break;
        case EV_LINK_DEAD:
            Serial.println("EV_LINK_DEAD");
            break;
        case EV_LINK_ALIVE:
            Serial.println("EV_LINK_ALIVE");
            break;
        || case EV_SCAN_FOUND:
        ||    Serial.println(F("EV_SCAN_FOUND"));
        ||    break;
        case EV_TXSTART:
            Serial.println("EV_TXSTART");
            break;
        case EV_TXCANCELED:
            Serial.println("EV_TXCANCELED");
            break;
        case EV_RXSTART:
            break;
        case EV_JOIN_TXCOMPLETE:
            Serial.println("EV_JOIN_TXCOMPLETE: no JoinAccept");
            break;
        default:
            Serial.print("Unknown event: ");
            Serial.println((uint8_t)Event);
            break;
    if(LMIC.opmode & OP_TXRXPEND)
        Serial.println("OP_TXRXPEND, not sending");
    else
        LMIC_setTxData2(1, Payload, sizeof(Payload) - 1, 0);
        Serial.println("Packet queued");
void setup()
    Serial.begin(115200);
    Serial.println("[INFO] Starting...");
    os_init();
    LMIC_reset();
    Transmit(&TransmitJob);
void loop()
    os_runloop_once();
A Dragino DLOS8 is used as a gateway and this gateway is integrated into TTN. The application prints
[INFO] Starting...
Packet queued
6709: EV_JOINING
67087: EV_TXSTART
460818: EV_JOIN_TXCOMPLETE: no JoinAccept
but TTN displays a successful join.
How can I fix this problem?
There is something wrong with your frequency. We are not allowed to transmit on 923.3 MHz in EU.
But what is the reason for this? The frequency plan for the gateway is Europe 868 MHz and the application for the Heltec is compiled with -DCFG_eu868=1 and -DCFG_sx1276_radio=1.
Maybe the gateway has the wrong frequency plan?
I have switched the gateway, so there is an issue with the previous one. It is working now.
@descartes: No I have selected the EU frequency plan in the gateway (same settings as in the current gateway).
Or the wrong handler on the gateways console?
@descartes
I have checked the settings in the gateway twice and there are all identical to the second gateway (which is working). The TTN settings for the gateway are the following:
