I’m trying to connect to the TTN through my Dragino DLOS8 with an ESP32 and a adafruit RFM95 breakout board. But I’m having some issues, it either Errors out(that was probably testing pins that wouldn’t work) or an infinite wall of:
13264610: EV_TXSTART
13666332: EV_JOIN_TXCOMPLETE: no JoinAccept
I’m not sure if this is a pinout issue, a configuration issue on the application/device in TTN console or simply in the gateway.
The current pinout:
.nss = 5,
.rxtx = LMIC_UNUSED_PIN,
.rst = 14,
.dio = {2, 27, 12},
The pins right now is random, but just a few that would be available on the finished board(nothing else plugged in while testing). My Dragino DLOS8 is added to TTN and setup according to their manual. I’m wondering if there is an issue with region setup in the code and the Dragino however. But also unsure if pinouts are fine. The SPI pins on the RFM95 is correct, already tested LoRa between two ESP32 successfully, so I know the components and radio work. Only wondering about the DIO pins. Another possibility is LoRaWAN version, can’t find out in the spec what the RFM95 uses.
Pin reference though, based on my wroom 32 devkit:
SPI MOSI: 23
SPI MISO: 19
SPI SCK: 18
SPI SS/CS: 5
Reset: 14
Full code:
* Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
* Copyright (c) 2018 Terry Moore, MCCI
* Permission is hereby granted, free of charge, to anyone
* obtaining a copy of this document and accompanying files,
* to do whatever they want with them without any restriction,
* including, but not limited to, copying, modification and redistribution.
* NO WARRANTY OF ANY KIND IS PROVIDED.
* This example sends a valid LoRaWAN packet with payload "Hello,
* world!", using frequency and encryption settings matching those of
* the The Things Network.
* This uses OTAA (Over-the-air activation), where where a DevEUI and
* application key is configured, which are used in an over-the-air
* activation procedure where a DevAddr and session keys are
* assigned/generated for use with all further communication.
* Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
* g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
* violated by this sketch when left running for longer)!
* To use this sketch, first register your application and device with
* the things network, to set or generate an AppEUI, DevEUI and AppKey.
* Multiple devices can use the same AppEUI, but each device has its own
* DevEUI and AppKey.
* Do not forget to define the radio type correctly in
* arduino-lmic/project_config/lmic_project_config.h or from your BOARDS.txt.
#include <Arduino.h>
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// For normal use, we require that you edit the sketch to replace FILLMEIN
// with values assigned by the TTN console. However, for regression tests,
// we want to be able to compile these scripts. The regression tests define
// COMPILE_REGRESSION_TEST, and in that case we define FILLMEIN to a non-
// working but innocuous value.
#ifdef COMPILE_REGRESSION_TEST
# define FILLMEIN 0
#else
# warning "You must replace the values marked FILLMEIN with real values from the TTN control panel!"
# define FILLMEIN (#dont edit this, edit the lines that use FILLMEIN)
#endif
// 0x70.
static const u1_t PROGMEM APPEUI[8]={ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
static const u1_t PROGMEM DEVEUI[8]={ removed };
// practice, a key taken from ttnctl can be copied as-is.
static const u1_t PROGMEM APPKEY[16] = { removed };
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 60;
// Pin mapping
.nss = 5,
.rst = 14,
.dio = {2, 27, 12},
void printHex2(unsigned v) {
v &= 0xff;
if (v < 16)
Serial.print('0');
Serial.print(v, HEX);
void do_send(osjob_t* j){
} else {
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
break;
case EV_BEACON_FOUND:
break;
case EV_BEACON_MISSED:
break;
case EV_BEACON_TRACKED:
break;
case EV_JOINING:
break;
case EV_JOINED:
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("AppSKey: ");
for (size_t i=0; i<sizeof(artKey); ++i) {
if (i != 0)
Serial.print("-");
printHex2(artKey[i]);
Serial.println("");
Serial.print("NwkSKey: ");
for (size_t i=0; i<sizeof(nwkKey); ++i) {
if (i != 0)
Serial.print("-");
printHex2(nwkKey[i]);
Serial.println();
LMIC_setLinkCheckMode(0);
break;
|| case EV_RFU1:
|| Serial.println(F("EV_RFU1"));
|| break;
case EV_JOIN_FAILED:
break;
case EV_REJOIN_FAILED:
break;
case EV_TXCOMPLETE:
if (LMIC.dataLen) {
Serial.print(F("Received "));
Serial.print(LMIC.dataLen);
// Schedule next transmission
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
// data received in ping slot
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
|| case EV_SCAN_FOUND:
|| Serial.println(F("EV_SCAN_FOUND"));
|| break;
case EV_TXSTART:
break;
case EV_TXCANCELED:
Serial.println(F("EV_TXCANCELED"));
break;
case EV_RXSTART:
/* do not print anything -- it wrecks timing */
break;
case EV_JOIN_TXCOMPLETE:
Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
break;
default:
break;
void setup() {
Serial.begin(115200);
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
// LMIC init
os_init();
LMIC_reset();
do_send(&sendjob);
void loop() {
os_runloop_once();
Edit:
I’ve done some digging, my lmic_project_config was set to north american region, now I’m set to EU
The gateway is getting the requests and TTN is getting messages like this:
"name": "gs.up.receive",
"time": "2021-09-08T08:06:14.660592704Z",
"identifiers": [
"gateway_ids": {
"gateway_id": "a84041ffff1f95b4-test"
"gateway_ids": {
"gateway_id": "a84041ffff1f95b4-test",
"eui": "A84041FFFF1F95B4"
"data": {
"@type": "type.googleapis.com/ttn.lorawan.v3.UplinkMessage",
"raw_payload": "AAAAAAAAAAAAcLPVftAEUAJMTh2y9Vs=",
"payload": {
"m_hdr": {},
"mic": "HbL1Ww==",
"join_request_payload": {
"join_eui": "0000000000000000",
"dev_eui": "025004D07ED5B370",
"dev_nonce": "4E4C"
"settings": {
"data_rate": {
"lora": {
"bandwidth": 125000,
"spreading_factor": 7
"coding_rate": "4/5",
"frequency": "868300000",
"timestamp": 601685179,
"time": "2021-09-08T08:06:14.639024Z"
"rx_metadata": [
"gateway_ids": {
"time": "2021-09-08T08:06:14.639024Z",
"rssi": -39,
"channel_rssi": -39,
"snr": 10.2,
"uplink_token": "CiMKIQoVYTg0MDQxZmZmZjFmOTViNC10ZXN0EgioQEH//x+VtBC7+fOeAhoMCPbd4YkGEMvN+LoCIPj07LnBEQ==",
"channel_index": 1
"received_at": "2021-09-08T08:06:14.660481739Z",
"correlation_ids": [
"gs:conn:01FF22Y82WGE9C0JD107HY1YY2",
"gs:uplink:01FF272WW4E4ERK0M6TR3JR6S9"
"origin": "ip-10-100-12-248.eu-west-1.compute.internal",
"context": {
"tenant-id": "CgN0dG4="
"visibility": {
"rights": [
"RIGHT_GATEWAY_TRAFFIC_READ",
"unique_id": "01FF272WW4Z9XZFVJW7EDG7JD9"
Not sure how to parse this info for an error.
