EV_JOIN_TXCOMPLETE: no JoinAccept Googling didn’t solve the problem so i’m repeating old question: what to do in this case? This time is maybe slightly different circumstances.
This tuesday one of my DIY node (RFM95, Arduino Mega Core, LMIC mcci-catena v4.1.0) and all Microclimate devices stopped to joining. More or less at the same time. All other nodes works fine all the time.
Is this only coincidence or is there any same reason of failure of mentioned devices?
Next question is how to effectively approach to debug such an error? Timing and wrong pin connection or mapping is usual reason, but in this case I’m dealing with different nodes from Mclimate (Vicki and AQI). Even if I made a mistake at DIY node, I couldn’t made this with other Mclimate nodes. I didn’t make any firmware upgrade. They just stopped to join. As long as I know, TTN made an upgrade this week. Could be this upgrade the reason? I’m running out of ideas …
BTW: I have two different GWs in the house, level of signal is high and other nodes work fine
Thank You!
