I use the following code to communicate with my TTN (Europe):
#include <SPI.h>
#include <WiFi.h>
#include <lmic.h>
#include <hal/hal.h>
#include <Arduino.h>
// 0x70.
static const u1_t PROGMEM APPEUI[8] = { 0x15, 0x44, , , , , 0x84, 0xEA };
void os_getArtEui(u1_t* buf){ memcpy_P(buf, APPEUI, 8); }
static const u1_t PROGMEM DEVEUI[8] = { 0x2C, 0x4F, , , , , 0x70, 0x00 };
void os_getDevEui(u1_t* buf){ memcpy_P(buf, DEVEUI, 8); }
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] = { 0x14, 0x5B, , , , , , , , , , , , , 0x3A, 0xDD };
void os_getDevKey(u1_t* buf){ memcpy_P(buf, APPKEY, 16); }
static uint8_t Payload[] = "Hello, world!";
static osjob_t TransmitJob;
.nss = 18,
.rxtx = LMIC_UNUSED_PIN,
.rst = 14,
.dio = {26, 35, LMIC_UNUSED_PIN},
const uint8_t TX_INTERVAL = 60;
void Transmit(osjob_t* Job);
void printHex2(unsigned v)
v &= 0xff;
if (v < 16)
Serial.print('0');
Serial.print(v, HEX);
void onEvent(ev_t Event)
Serial.print(os_getTime());
Serial.print(": ");
switch(Event)
case EV_SCAN_TIMEOUT:
Serial.println("EV_SCAN_TIMEOUT");
break;
case EV_BEACON_FOUND:
Serial.println("EV_BEACON_FOUND");
break;
case EV_BEACON_MISSED:
Serial.println("EV_BEACON_MISSED");
break;
case EV_BEACON_TRACKED:
Serial.println("EV_BEACON_TRACKED");
break;
case EV_JOINING:
Serial.println("EV_JOINING");
break;
case EV_JOINED:
Serial.println("EV_JOINED");
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("AppSKey: ");
for(size_t i = 0; i < sizeof(artKey); ++i)
if(i != 0)
Serial.print("-");
printHex2(artKey[i]);
Serial.println("");
Serial.print("NwkSKey: ");
for(size_t i = 0; i < sizeof(nwkKey); ++i)
if(i != 0)
Serial.print("-");
printHex2(nwkKey[i]);
Serial.println();
LMIC_setLinkCheckMode(0);
break;
case EV_JOIN_FAILED:
Serial.println("EV_JOIN_FAILED");
break;
case EV_REJOIN_FAILED:
Serial.println("EV_REJOIN_FAILED");
break;
case EV_TXCOMPLETE:
Serial.println("EV_TXCOMPLETE (includes waiting for RX windows)");
if(LMIC.txrxFlags & TXRX_ACK)
Serial.println("Received ack");
if(LMIC.dataLen)
Serial.print("Received ");
Serial.print(LMIC.dataLen);
Serial.println(" bytes of payload");
for (int i = 0x00; i < LMIC.dataLen; i++)
Serial.print(LMIC.frame[LMIC.dataBeg + i], 16);
Serial.print(" - ");
os_setTimedCallback(&TransmitJob, os_getTime() + sec2osticks(TX_INTERVAL), Transmit);
break;
case EV_LOST_TSYNC:
Serial.println("EV_LOST_TSYNC");
break;
case EV_RESET:
Serial.println("EV_RESET");
break;
case EV_RXCOMPLETE:
Serial.println("EV_RXCOMPLETE");
break;
case EV_LINK_DEAD:
Serial.println("EV_LINK_DEAD");
break;
case EV_LINK_ALIVE:
Serial.println("EV_LINK_ALIVE");
break;
case EV_TXSTART:
Serial.println("EV_TXSTART");
break;
case EV_TXCANCELED:
Serial.println("EV_TXCANCELED");
break;
case EV_RXSTART:
break;
case EV_JOIN_TXCOMPLETE:
Serial.println("EV_JOIN_TXCOMPLETE: no JoinAccept");
break;
default:
Serial.print("Unknown event: ");
Serial.println((uint8_t)Event);
break;
if(LMIC.opmode & OP_TXRXPEND)
Serial.println("OP_TXRXPEND, not sending");
else
LMIC_setTxData2(1, Payload, sizeof(Payload) - 1, 0);
Serial.println("Packet queued");
void setup(void)
Serial.begin(115200);
Serial.println("[INFO] Starting...");
SPI.begin(5, 19, 27);
os_init();
LMIC_reset();
#if defined(CFG_eu868)
// Set up the channels used by the Things Network, which corresponds
// to the defaults of most gateways. Without this, only three base
// channels from the LoRaWAN specification are used, which certainly
// works, so it is good for debugging, but can overload those
// frequencies, so be sure to configure the full frequency range of
// your network here (unless your network autoconfigures them).
// Setting up channels should happen after LMIC_setSession, as that
// configures the minimal channel set.
// NA-US channels 0-71 are configured automatically
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI); // g-band
LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK, DR_FSK), BAND_MILLI); // g2-band
// TTN defines an additional channel at 869.525Mhz using SF9 for class B
// devices' ping slots. LMIC does not have an easy way to define set this
// frequency and support for class B is spotty and untested, so this
// frequency is not configured here.
#elif defined(CFG_us915)
// but only one group of 8 should (a subband) should be active
// TTN recommends the second sub band, 1 in a zero based count.
// https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json
LMIC_selectSubBand(1);
#endif
LMIC.dn2Dr = DR_SF9;
// Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
LMIC_setDrTxpow(DR_SF7, 14);
Transmit(&TransmitJob);
void loop(void)
os_runloop_once();
delay(1000);
And the following device in TTN:
TTN receives and displays the data in the device, but I don´t get a join accept.
51566429: EV_TXSTART
51566500: TXMODE, freq=868100000, len=23, SF=9, BW=125, CR=4/5, IH=0
start single rx: now-rxtime: 1429
51941461: RXMODE_SINGLE, freq=868100000, SF=9, BW=125, CR=4/5, IH=0
rxtimeout: entry: 52003904 rxtime: 51940027 entry-rxtime: 63877 now-entry: 62504 rxtime-txend: 311126
start single rx: now-rxtime: 126679
52128961: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 52191404 rxtime: 52002277 entry-rxtime: 189127 now-entry: 62504 rxtime-txend: 373376
52253926: EV_JOIN_TXCOMPLETE: no JoinAccept
52316403: engineUpdate, opmode=0xc
What´s the reason for this?
