I have the problem that I cant connect to TTN3 over LAN. The logs arent very helpful…
I am in a conpany network. But if connect over the Gateway Acces Point the Internet is working fine…
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ ################## Report at: 2024-06-03 09:27:26 UTC ##################
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ ### [UPSTREAM] ###
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # RF packets received by concentrator: 0
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # RF packets forwarded: 0 (0 bytes)
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # PUSH_DATA datagrams sent: 0 (0 bytes)
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # PUSH_DATA acknowledged: 0.00%
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ ### [DOWNSTREAM] ###
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # PULL_DATA sent: 1 (100.00% acknowledged)
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # RF packets sent to concentrator: 0 (0 bytes)
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # TX errors: 0
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # BEACON queued: 0
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # BEACON sent so far: 0
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # BEACON rejected: 0
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ ### [PPS] ###
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: REPORT~ # SX1301 time (PPS): 182887594
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: INFO: [jit] queue is empty
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: INFO~ ### [GPS] ###
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: INFO~ # GPS sync is disabled
Mon Jun 3 10:27:26 2024 daemon.info lora_pkt_fwd[20640]: INFO~ ##### END #####
