Nke Watteco Thr sensor
Any support questions you might have can be asked here:
https://www.thethingsnetwork.org/marketplace/product/thr-sensorimage
I just got a Flash O’ sensor, I am having a difficulty in shorten the reporting time, and basically the ZCL commands usage.
I can send a downlink on FPort 125, but don’t know how to write the commands, can you show me an example of a downlink command for example to check the firmware?
Thanks.
http://support.nke-watteco.com/flasho/
I already read that, and couldn’t come up with the format of the downlink packet I should send …I just need one simple example and will try to figure how it works.
Since i got the answer, i wanted to share it,
to set the device to send every minute, send this command on FPort 125:
11 06 00 0f 00 04 02 23 00 00 80 01 00 00 00 00 ( 80 01 = 1minute)
to send a message every 24 hours = 1440 minutes
11 06 00 0f 00 04 02 23 00 00 85 a0 00 00 00 00
