My first gateway.
I’ve configured a brand new TTIG-868 following the latest guidelines. Claiming the gateway. https://www.thethingsindustries.com/docs/gateways/thethingsindoorgateway/
The green led flashes fast. Tried rebooting after one hour: same thing. Shut down for the night, booted in the morning: same problem.
I can ping the gateway from my pc.
I’ve emailed the distributor, no answer yet.
EUI: 58A0CBFFFE803352
Serial Number: TBMH100868009268
Hi
Good thinking of you.
I now started the gateway in another building, so no wifi connection and the blinking is 0.5sec.
So perhaps the manual is not 100% correct , or blinking speed is not the same as in the manual.
But as I can ping the TTIG from my laptop on the same network (when at home) the wifi connection needs to be ok…or…?
thx
Ugo
tested at home: led is still fast blinking 1/4s. Big difference than when the “no wifi” blinking pattern.
Firewall is not blocking outgoing traffic.
The 5 min setup is now 1.5 days.
Too bad one cann’t connect to the TTIG and do some testing, or can you?
I’v tested the following ports from a laptop connected to the same wifi as the gateway. All are responding.
So not blocked by firewall or ISP.
TCP: lns.eu.thethings.network -p 443
TCP: rjs.sm.tc -p 9191
TCP: rjs.sm.tc -p 9h.sm.tc -p 7007
UDP 1.1.1.1 -p 53 (DNS server used)
Still 1/4s green led flashing and status disconnected in TTS/CE
Anything else I can try?
thanks
Ugo
Hi, thank you for helping.
I think the screenshot is unclear. This is the EUI I’ve entered in TTS/CE:
I used CB, or did I make a mistake somewhere else?
Hi, that’s OK…
I didn’t see any other errors. I also had problems the first time, but that was because I had registered the TTIG. After I deleted the gateway and then only claimed, the gateway was connected.
Hi, I face a similar pb with one of my TTIG (EUI 58A0CBFFFE8019CF). It worked for a couple of weeks on TTN V3. On last Friday, it appeared as “disconnected” on the TTN V3 console and stopped relaying messages from my sensors. I checked the LED : it blinks green rapidly (every 1/4s). Once, I also saw it blinking alternatively green and red. If I unplug and replug it, after a reboot, the led blinks green rapidly (every 1/4s).
Today, I plugged another TTIG in the same room (EUI 58A0CBFFFE8021F1) and this one connects correctly to the TTN V3 console (fixed green led).
Same problem here. It use to work at the beginning but not any more. Green LED fast blinking.
I found the same issue posted on the web, TTIG purchased through the Antratrek as mine.
Any solution for solving the problem?
