Hi All,
Just installed new firmware (mPower™ Edge Intelligence 5.1.5) on a MTCDT-247A (AEP AUS)
and tried the installer script (which ran fine on the previous 1.4.17 firmware I had on it) and get the following error
installer.sh: line 733: /var/config/lora/global_conf_src: Permission denied
FATAL ERROR: could not obtain gateway id, Lora card not found
even though the card shows up within the Multitech GUI no worries
any ideas?
regards
Paul
So, is there such file global_conf_src
in that folder /var/config/lora/
? If yes, what are its file permissions? Something like ls -l /var/config/lora/global_conf_src
should tell.
(If further debugging is needed then please link to the installer script as well?)
kersing
(Jac Kersing)
March 11, 2020, 7:43am
3
Could you run the install script using sudo?
sudo bash ./installer.sh
Yep, you must running the installer after updating again with the sudo command.
Then everything will go well.
Just done last evening
yep thanks everyone, worked a treat, back online
This tutorial could do with a little note for novices like me
https://www.thethingsnetwork.org/docs/gateways/multitech/aep.html
cheers
Paul
