although I followed every tutorial I could find, especially the official ones, I am still without success. I try to add the netvox R718a and the netvox R718N315 to my application. I use the Things network database driven way.
- I am running two gateways that work obviously as they provide the data from a dragino sensor.
- The dragino works fine in my application. So the app also seems to work
- I used the “Add end device” feature of the console and then the Device Repository.
- As “Live data” I get “Create end device”, but “No activity yet” and Session information “This device has not joined the network yet”.
- At the gateway I see an uplink message. Here is the complete JSON:
"name": "gs.up.receive",
"time": "2022-08-11T10:21:55.460502649Z",
"identifiers": [
"gateway_ids": {
"gateway_id": "fst-stecker1",
"eui": "58A0CBFFFE8046AA"
"data": {
"@type": "type.googleapis.com/ttn.lorawan.v3.GatewayUplinkMessage",
"message": {
"raw_payload": "ACiYfscQIHxKR4cBABB6EwBBrntjo7k=",
"payload": {
"m_hdr": {},
"mic": "e2OjuQ==",
"join_request_payload": {
"join_eui": "4A7C2010C77E9828",
"dev_eui": "00137A1000018747",
"dev_nonce": "AE41"
"settings": {
"data_rate": {
"lora": {
"bandwidth": 125000,
"spreading_factor": 7
"coding_rate": "4/5",
"frequency": "868500000",
"timestamp": 1353804475,
"time": "2022-08-11T10:21:55.388025999Z"
"rx_metadata": [
"gateway_ids": {
"time": "2022-08-11T10:21:55.388025999Z",
"rssi": -58,
"channel_rssi": -58,
"snr": 6.75,
"location": {
"latitude": 48.57764398064623,
"longitude": 7.921693149519837,
"altitude": 120,
"source": "SOURCE_REGISTRY"
"uplink_token": "ChoKGAoMZnN0LXN0ZWNrZXIxEghYoMv//oBGqhC71cWFBRoMCMOw05cGEODAwNsBIPjUo6izkgcqDAjDsNOXBhCPnYO5AQ==",
"received_at": "2022-08-11T10:21:55.431427663Z"
"received_at": "2022-08-11T10:21:55.460333152Z",
"correlation_ids": [
"gs:conn:01GA58TPDPHGTQPS828W082089",
"gs:uplink:01GA66SHW4V70J5Z5GW1V60FHD"
"band_id": "EU_863_870"
"origin": "ip-10-100-14-219.eu-west-1.compute.internal",
"context": {
"tenant-id": "CgN0dG4="
"visibility": {
"rights": [
"RIGHT_GATEWAY_TRAFFIC_READ"
"unique_id": "01GA66SHW478HMMW2EE2MKKHFQ"
The “only” thing is, that there is no connection to the network and so no data in the app.
I know that this is a complete beginners problem, but I tried for three days now with the tutorial, forum search and youtube videos. I learned a lot, especially about v2 vs v3. But still there is no success. Please help!
