hi
I’m installing my fourth multitech conduit gateway (MTCDT-247A
Firmware1.6.4) after this tutorial and there are problems:
https://www.thethingsnetwork.org/docs/gateways/multitech/aep.html
nc -v bridge.eu.thethings.network 1883
Warning: Inverse name lookup failed for `52.169.76.203’
bridge.eu.thethings.network [52.169.76.203] 1883 open
Description (from TTN): Gateway from IBBD.AT
Frequency plan (from TTN): EU_863_870Is the information correct?
- Yes
- No
#? 1
Installing TTN Multi Protocol Packet Forwarder
Installing mp-packet-forwarder (3.0.21) on root.
Configuring mp-packet-forwarder.
Configuring useradd.
PATH=${PATH}:/sbin:/usr/sbin
Get up-to-date TTN configuration for packet forwarder
Starting ttn-packet-forwarder: OK
The installation is now complete.
Check the gateway output using:
tail -f /var/log/lora-pkt-fwd.log
(It might take some minutes for the first output to appear!)
Check the gateways last seen status in the TTN console after
a few minutes to verify the setup is working correctly
admin@mtcdt:~# ^C
admin@mtcdt:~# tail -f /var/log/lora-pkt-fwd.log
18:03:36 INFO: Statusstream data is enabled
18:03:36 INFO: Beacon is disabled
18:03:36 INFO: Packet logger is disabled
18:03:36 INFO: Flush output after statistic is disabled
18:03:36 INFO: Flush after each line of output is disabled
18:03:36 INFO: Watchdog is disabled
18:03:36 INFO: Contact email configured to “xxx”
18:03:36 INFO: Description configured to “Gateway from IBBD.AT”
18:03:36 INFO: [Transports] Initializing protocol for 1 servers
18:03:39 ERROR: [TTN] Connection to server “bridge.eu.thethings.network” failed, retry in 30 seconds
