Multitech Conduit mlinux DHCP issues
Hi all,
For those of you using Multitech Conduit mlinux as your gateway I’d be interested to hear if you’re having problems with DHCP.
Reproducible scenario:
  1. Router with DHCP server is disconnected or powered off
  2. Conduit powers up or reboots, fails to get a DHCP lease
  3. Router with DHCP server is reconnected or powered up (conduit’s eth0 link state changes)
  4. Conduit never asks for a DHCP lease again. Device is useless until reboot.
It seems link state changes on mlinux don’t cause a DHCP Discover or Request. The only way to make a reliable gateway configuration is to use static IP addresses (which have their own limitations). The outdoor IP67 conduit has an external PoE injector (48v) so cannot be remotely reset without additional equipment or a site visit. Bah.
Can anyone suggest a fix for this?
Ben
The only reliable solution is to use static IP.
Thanks. That’s not the question I was asking though.
Or is it not the answer you wanted to get? You could add a script to the conduit that checks for a valid IP address every minute and restart the dhcp client if there is no valid IP address for 5 minutes. Another solution would be to replace the dhcp client with one that does not suffer these issues. The problem with both options is they might not work reliably.
Have you tried asking the question at the forum at MultiTech.net?
For remote instances, perhaps a raspberry pi and a usb cable to the serial port would be a half useful workaround, at least while Conduit sort out there software! Im finding having the base on my desk is way more useful than I thought and would hate to have to go onto the roof (or further) every time something goes wrong!
PS: Yes DHCP is kinda broken :confused:
@kersing It’s not that I didn’t appreciate the help, but I was trying to continue using DHCP for consistency. I knew I could use static addressing, but thought someone may have a fix. Your suggestion about using a DHCP watchdog script is fair, perhaps a cron job is in my future.
I will ask the question at the Multitech forum too, but this one’s much nicer.
Ben
@timmyhadwen I haven’t experienced any problems that weren’t fixable with ssh yet except the DHCP problem. Have you had any issues that need USB serial access?
I ask mainly because I have one on a roof and it’d involve security torx screws and field engineers and a personal visit to resolve.
I’m running a Multitech with DHCP for about half a year now without any problems. But I have the luxury that it’s relatively easy for me to get physical access to the box if it was needed. Also the power to the multitech has been stable. I have rebooted it remotely quite a few times and it always came back up.
I did configure the network setup to send the hostname to the DHCP server, so I can access it by name instead of only ip address.
Our corporate policy is about to remove all devices with static IP and use DHCP for security reasons
(I have latest Mutitech firmware) but DHCP is still unreliable, any advise using settings in the gateway device to correct this appreciated?
Have you asked the same question at the MultiTech forum? I expect you will get a better response over there.
I found the Issue with Multitech Support
I had set Eth0 to DHCP Client LAN mode not WAN mode
Multitech Support Details:
  1. Go to: Setup -> Network Interfaces -> Eth0 -> Click on ‘Pencil’ icon
    and set ‘Direction’ -> WAN and ‘Mode’ -> DHCP Client -> Click on ‘Submit’ button and do a save and reboot.
    And see if this helps ?
    Notes: If you are getting a warning - enable WAN access, then click OK.
  2. If it is still failed, I would try as follow:
    • Try to factory default the unit by either go to Administration -> Save/Restore -> Reset to factory default configuration.
      Or push and hold the ‘reset’ button for 40+ secs and let it go.
      Connect an ethernet cable from your laptop directly into the Conduit ethernet port and configure your laptop
      with ip address: 192.168.2.2. Make sure you turn off the Wifi on your laptop.
    • Accessing the Conduit at: https://192.168.2.1 and go through the ‘Commission mode’ to create an admin account. Then
      log into the Conduit with that account. Go through ‘First Time Setup’ wizzard and accepted all the default value.
      Click on ‘Save and Reboot’.
    • Access the unit again at: https://192.168.2.1 and go to Setup -> Network Interfaces -> Eth0 -> Click on ‘Pencil’ icon
Hope this helps others experiencing the similar issues
In addition our site blocks ICMP / Ping
and the fail over between LAn, Wifi, was set to use Ping, it has been changed to use TCP port 80 and now fail over also works properly
