MultiTech Conduit AEP frequency
Hi, im quite new to LoRa, I have setup a MutliTech Conduit AEP with TTN firmware and I am currently testing it using an Arduino UNO + DraginoShield. The node is sending packets at different frequencies from 915 to 928 MHz but when I check the traffic using TTN, the conduit does not pick up anything from 918 to 928. Also im in Australia, could someone help me out with what i must do. Otherwise the transmission is very reliable.
Kind Regards
Yas
A few questions to work out what is going on.
Did you use this Packet Forwarder https://www.thethingsnetwork.org/docs/gateways/multitech/aep.html ?
Does your sketch ensure it is using sub band 2, what TTN uses in AU915? https://www.thethingsnetwork.org/docs/lorawan/frequency-plans.html#au915-928
cheers
Paul
Hi sorry the problem has been solved thanks for the reply!
