Hi all,
core question: Is there some reading material on the way how the integration and Payload function work together?
The reason for this question
I have one device/node working yeah
I did use the default cayenne integration and it worked after a while yeah
(see also:Cayenne integration: Where is my payload? )
But then I thought… There is also an IFTT integration. Lets also use this. Because reuse of data is cool. And adding a second integration is also no issue in the backend.
Writing some Decode function to get transform the Cayenne data because IFTT needs payload form data.
So this done and it works
But now Cayenne does not work anymore.
My guess is that Cayenne is not recieving the payload of the node anymore, and that the payload function result is send to both integrations.
Is there some documentation where I can double check this assumption?
And can read the rationale behind this, because how big is the change that different integrations want to recieve the same payload format or somehting…
Thanks anybody for helping in learning how the payload and integration complex is working
Grtz Edzo
