I promise, I did my Google research before posting this:
I use home assistant with the MQTT add on.
I try to configure my MQTT Broker to bridge to the TTN MQTT broker.
Here is an error-message I receive:
Connection Refused: unacceptable protocol version
Anyone had this issue and has a solution for me?
Thanks a lot!
Albert
My config for MQTT Broker:
# Bridge to The Things Network
connection bridge
address eu1.cloud.thethings.network:1883
bridge_protocol_version mqttv311
remote_username xxx
remote_password xxx
# topic # both 0 ttn/ APPID/devices/
bridge_insecure false
topic # out 0
topic # in 0
cleansession true
The log message:
1647188389: Connecting bridge bridge (eu1.cloud.thethings.network:1883)
1647188389: mosquitto version 1.6.12 running
1647188389: Connection Refused: unacceptable protocol version
1647188389: Socket error on client local.core-mosquitto.bridge, disconnecting.
Can you try a vanilla client - like MQTT Explorer - that will verify all the credentials, details etc and let us know how you get on.
If they work OK, we can look at the details of your Home Assistant - but to cut to the chase on that bit, is it up to date and what MQTT version does it support?
This post was moved from another topic because double-posted.
Don’t double-post!
bluejedi
Dear All!
Here is my mqtt.yaml - and the config I have in my mqtt.conf…
However the bridge to the MQTT Add-On is not working. I opened another thread as well for that.
Does not match the configuration you show in the top post:
In your double post (post right above) the bridge_protocol_version is missing which can explain the error message but it does not match the configuration that you show on top.
You should now (with protocol version specified) probably see a different error message which is not shown in your posts. FYI: Filename should be mosquitto.conf (all lower case).
A possible solution for your problem was already described here:
I struggled with the same “unacceptable version” error, adding the bridge_protocol_version got rid of that error for me, thx,
However, i still get connection errors. A test with mosquitto_sub in Home Assistant Terminal worked fine, from my perspective the issue seems to be with the Mosquitto Addon itself.
Hello - this is my current (working) configuration:
MQTT - Config in HA (snipplet)
customize:
active: true
folder: mosquitto
mosquitto/mqtt.conf
connection bridge
remote_username ********@ttn
remote_password *******
topic # out 0
topic # in 0
cleansession true
#autosave_interval 30
#autosave_on_changes false
I still get this message in the logs, but apparently has nothing to do with TTN-MQTT, because I receive all messages.
A hint - use MQTT Explorer to debug the messages
