MQTT failure - Meshed Australia
I am trying to connect to my application’s activations and messages on TTN via MQTT using a mosquitto subscribing client following the (what look out of date) instructions.
Is the Australia MQTT host
  • au.thethings.network or
  • au.meshed.handler or
  • something else?
I am just getting this error with both the above
Unable to connect (look up error.)
I have used the mosquitto client subscribing to various other clients before, without error.
thethings.meshed.com.au :slight_smile:
Thanks @Maj. Unfortunately that now returns:
Connection Refused: not authorised
are there further parameters needed beyond the APP ID and APP KEY?
You need to use the Access Key rather than the AppKey.
This will work:
mosquitto_sub -h thethings.meshed.com.au -u myApp -P 'myAccessKey' -t '#'
Woo Hoo! I have got the data coming through. Thanks a lot @Maj
I think I had better request some changes to TTN Documentation pages!
Clone the documentation GitHub repo, make the changes yourself and create a pull request…
will do. First ever pull request so I will ask the guys at TTN to be gentle.
