A novice question.
I registered my 3 devices (sensors) in one application. I could see that they all sent data, but that the data was encoded.
Reading some more I learned that the data was encoded and that I needed to use a decoder script to make sense of the data.
At this point I discovered that the decoder function is written for each device and that this javascript comes with my device. Two of my devices comes from the same manufacturer and has a decoder function that can handle the data for the two devices.
What I needed to do was to create a new application and then connect one of the sensors to his application. This so that i could register the decoder function that makes sense of the data it sends.
I could not find a âMove deviceâ button in the console so I decided to just delete it and register it on a new application.
I wrote down all the information about the sensor from its settings page (Device EUI, Application EUI and so on)
When registering the device on the new application I typed in the Device EUI and so on. But the status of the device is ânever seenâ.
Moving a device from one application to another must be a thing that is done quite frequently - but Iâm not able to find the procedure. Iâm grateful for any help on this simple question.
Move of devices in my experience always requires a reboot. (ABP as well as OTAA)
Btw I donât think it is done frequently, most people will create a new node in an application and reprogram the device with the new credentials. That usually implies a reboot/rejoin so that gets things working.
I took out the battery and inserted it again. I see in the gateway traffic that the device is sending data.
But the sensor status is still ânever seenâ
The device is a Tabs Model TBHH100 - Smart Building Sensors - Temperature & Humidity
Hi @terchris,
I currently have the same problem you had. I removed a device (same Tabs device in fact) from one application and registered it with a new application. I can see traffic going though my gateway but the device is ânever seenâ. I also tried removing/replacing the battery. Presumably the device needs to be reset somehow and/or go through OTAA again? Iâm not sure how to do this. Did you get your device to work in the end?
