Is there any information about minimum system requirement to deploy a stack v3 environment depending on gateways and devices?
I’ve search in the forum and the webpage but didn’t find any relevant information about this topic, only one but was planing to install it on cloud system. I’ll need to install stack on a hardware that will not change (I’m not the owner).
We don’t really have guidelines for this. Most of the single-instance deployments that I know of got started on a VM with 2VCPUs and 4-8GB of memory. That should be enough for a small network. Of course the entire idea of running in the cloud is that you’re able to spend less money while you’re small, and scale your deployment when you grow.
