Hi all!
I’m at a loss. I’ve got a brand new MikroTik wAP LoRa8 but it’s not registering to The Things Network.
I’ve set it up as follows:
updated the RouterOS to 6.49.7 (stable)
reset configuration
bridged all interfaces
set up DHCP client on the bridge to get an IP address
used “LoRa Device - Hardware ID” as the “Gateway EUI” to add the gateway in TTN console
set “LoRa Device - Gateway ID” to a unique combination of sixteen numbers
used “LoRa Device - Gateway ID” as the “Gateway ID” in TTN console
set “LoRa Device - Network Servers” to “TTN V3 (eu1)” (eu1.cloud.thethings.network), which matches “Gateway Server address” in TTN console
set “Channel Plan” to “EU 868”
enabled LoRa on MikroTik
(I should probably disable forwarding messages with errors) -
tried both “Europe 863-870 MHz (SF9 for RX2 - recommended)” and “Europe 863-870 MHz (SF12 for RX2)” in TTN console
But the MikroTik keep showing as disconnected in TTN console:
Did some checks:
I am able to ping google.com through the terminal on the Mikrotik, so DNS is resolving
using torch on eth1, filtering for UDP on port 1700, I see IP addresses for TTN communicating with my MikroTik
I am receiving messages in the “LoRa - Traffic” tab
on my ISP’s router, I forwarded port 1700 (TCP+UDP) for the MikroTik, just in case
Anything I could try next? Or does anyone see an error I’ve made?
Best regards.
