I tried to migrate my RPi IMST iC880A GW to TTS V3 but it doesn’t work. I used Balena Cloud with repo of jpmeijers and did all necessary steps as described. “git push -f balena master” produces several errors and warnings:
W: Skipping acquire of configured file 'ui/binary-armhf/Packages' as repository 'http://archive.raspberrypi.org/debian bullseye InRelease' doesn't have the component 'ui' (component misspelt in sources.list?)
E: Package 'python-rpi.gpio' has no installation candidate
The command '/bin/sh -c install_packages wget build-essential libc6-dev git pkg-config protobuf-compiler libprotobuf-dev libprotoc-dev automake libtool autoconf python-dev python-rpi.gpio' returned a non-zero code: 100
Service: main
[Error] Error: The command '/bin/sh -c install_packages wget build-essential libc6-dev git pkg-config protobuf-compiler libprotobuf-dev libprotoc-dev automake libtool autoconf python-dev python-rpi.gpio' returned a non-zero code: 100
[Info] Built on arm03
[Error] Not deploying release.
The GW connects with V2 but not with V3. What could be wrong and how can I fix it?
It would appear its an issue encountered in other contexts as well with a less official library not being well handled across the deprecation of python2 in a quite recent OS install.
python-rpi.gpio is a python2 package.
The python3 package would by python3-rpi.gpio
But it’s not really the recommended way to interact with gpios, since it’s pi unique. There are more portable python solutions.
If the install is still trying to use python2, that’s probably going to cause a number of issues on a recent operating system image.
The issues has really nothing to do with TTN v3, but rather with having started over with an SD card containing a more recent operating system than was used in any previous success against v2.
I use the ch2i RPi hat that has different LEDs like led_heartbeat, led_down, led_error and led_packet. Is it possible to use these LEDs further? I even have sensors in the GW can I use these too?
My GW includes a small USV to ensure that it could safely shut down at power cut. I would like to include it in BalenaOS. Is that possible? I have to install a small daemon to detect a power cut and shut down the Pi.
Can anyone point me to a tutorial for using these features?
