The firmware doesn’t… But i can instruct people to simply remove the battery for a minute. I think that will do the trick
/offtopic
Also the single channel was already phased out in favor of the tti gateway. However on one location the coverage was gone. So the quick solution was to place the old gateway nearby the sensor.
Don’t worry about other users. The gateway don’t reach outside the room. It is a small development board. With only a few meters range.
In that case just add the devices with the same EUIs and keys to V3. For 5 devices I wouldn’t bother with the migration tools. In V2 change one byte of the key so when reset the device is forced to join V3.
Don’t forget to set your uplink decoder(s) and to update your integrations to the new data format.
Yeah, and I only had one pint officer, I measured it and there weren’t any other drivers on the road.
Please replace this ‘thing’ with a TTIG or PyGate or other low cost 8 channel gateway, you can not be sure what other devices are around that may be misled by your Single Channel Packet Forwarder.
