I try to interface a MICS 6814 based board like this one, without I2C support, with an arduino compatible TTGO V2 ESP32 board. I looked for a library supporting it, but I couldn’t find anything except code for the I2C interfaced sensor.
Did anybody used that sensor before and know how I may use it?
Indeed this is an analog sensor board : you need to read voltage(s) using ADC pins and then to calculate the actual values from that, which is not simple. And there seems to be a need for a calibration process every time you move the sensor to a new place.
A quick search on github lead me to this repository where someone implemented a version for raspberry pi - if you know what you are doing you might start from that.
