We are trying to connect two Lora modules but we are not getting RX
Send TX By This code
#include <SoftwareSerial.h>
SoftwareSerial loraSerial(10, 11);
String str;
void setup() {
//output LED pin
pinMode(13, OUTPUT);
led_off();
// Open serial communications and wait for port to open:
Serial.begin(9600);
loraSerial.begin(115200);
loraSerial.setTimeout(1000);
lora_autobaud();
led_on();
delay(1000);
led_off();
Serial.println("Initing LoRa");
loraSerial.listen();
str = loraSerial.readStringUntil('\n');
Serial.println(str);
loraSerial.println("sys get ver");
loraSerial.println("mac pause"); // Activates P2P transmission between the modules
// loraSerial.println("radio set bt 0.5");
// wait_for_ok();
loraSerial.println("radio set mod lora");
loraSerial.println("radio set freq 865100000");
loraSerial.println("radio set pwr 14");
loraSerial.println("radio set sf sf7");
loraSerial.println("radio set afcbw 41.7");
loraSerial.println("radio set rxbw 125");
// loraSerial.println("radio set bitrate 50000");
// wait_for_ok();
// loraSerial.println("radio set fdev 25000");
// wait_for_ok();
loraSerial.println("radio set prlen 8");
loraSerial.println("radio set crc on");
loraSerial.println("radio set iqi off");
loraSerial.println("radio set cr 4/5");
loraSerial.println("radio set wdt 60000"); //disable for continuous reception
loraSerial.println("radio set sync 12");
loraSerial.println("radio set bw 125");
Serial.println("starting loop");
void loop() {
led_on();
loraSerial.println("radio tx 3031");
led_off();
delay(2000);
void lora_autobaud()
String response = "";
while (response=="")
delay(1000);
loraSerial.write((byte)0x00);
loraSerial.write(0x55);
loraSerial.println();
response = loraSerial.readStringUntil('\n');
* This function blocks until the word "ok\n" is received on the UART,
* or until a timeout of 3*5 seconds.
int wait_for_ok()
if ( str.indexOf("ok") == 0 ) {
return 1;
else return 0;
void led_on()
digitalWrite(13, 1);
void led_off()
digitalWrite(13, 0);
RX Code
Wating For RX
String str;
char e ;
void setup() {
//output LED pin
//led_off();
Serial.begin(9600);
lora_autobaud();
led_on();
delay(1000);
led_off();
wait_for_ok();
wait_for_ok();
wait_for_ok();
loraSerial.println("radio set wdt 0"); //disable for continuous reception
void loop() {
//Serial.println("waiting for a message");
loraSerial.println("radio rx 0"); //continous reception
str = String("");
while(str=="")
if ( str.indexOf("radio_rx") == 0 ) {
Serial.print("packet: ");
Serial.println(e);
toggle_led();
else
Serial.println("Received nothing");
else
Serial.println("radio not going into receive mode");
delay(1000);
delay(1000);
int wait_for_ok()
return 1;
else return 0;
void toggle_led()
digitalWrite(13, !digitalRead(13));
void led_on()
void led_off()
