I tried to connect Healtec esp32 lora v2 do ttn via Dragino LPS8
And - I can see messages on gateway bookmark, but when I tried to connect it in Aplication bookmark - it failed.
my sketch is:
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>#include <U8x8lib.h>
#define DISABLE_PING 0
#define DISABLE_BEACONS 0static const u1_t PROGMEM APPEUI[8] = {0x7C, 0x0A, 0x89, 0x2B, 0x17, 0xAE, 0x48, 0x85};
void os_getArtEui(u1_t * buf) { memcpy_P(buf, APPEUI, 8);}static const u1_t PROGMEM DEVEUI[8] = {0x9F, 0x48, 0x05, 0xD0, 0x7E, 0xD5, 0xB3, 0x73};
void os_getDevEui(u1_t * buf) { memcpy_P(buf, DEVEUI, 8);}static const u1_t PROGMEM APPKEY[16] = {0x38, 0x3B, 0xD5, 0x7E, 0xB9, 0xA0, 0x0E, 0x60, 0xAA, 0x31, 0xE4, 0x1B, 0x9F, 0x44, 0xFB, 0xAE};
//static const u1_t PROGMEM APPKEY[16] = {0xAE, 0xFB, 0x44, 0x9F, 0x1B, 0xE4, 0x31, 0xAA, 0x60, 0x0E, 0xA0, 0xB9, 0x7E, 0xD5, 0x3B, 0x38};
void os_getDevKey(u1_t * buf) { memcpy_P(buf, APPKEY, 16);}
U8X8_SSD1306_128X64_NONAME_SW_I2C display_(/* clock=/ 15, / data=/ 4, / reset=*/ 16);
static uint8_t mydata = â00â;
static osjob_t sendjob;
const unsigned TX_INTERVAL = 60;
.nss = 18, // CS PIN
.rxtx = LMIC_UNUSED_PIN,
.rst = 14, // reset pin
.dio = {
26,
26,
26
};void printHex2(unsigned v) {
v &= 0xff;
if (v < 16)
Serial.print(â0â);
Serial.print(v, HEX);
}void onEvent(ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch (ev) {
case EV_JOINING:
Serial.println(F(âEV_JOININGâ));
break;case EV_JOINED:
Serial.println(F(âEV_JOINEDâ)); {
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
LMIC_getSessionKeys( & netid, & devaddr, nwkKey, artKey);
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print(âAppSKey: â);
for (size_t i = 0; i < sizeof(artKey); ++i) {
if (i != 0)
Serial.print(â â);
printHex2(artKey[i]);
Serial.println(ââ);
Serial.print("NwkSKey: â);
for (size_t i = 0; i < sizeof(nwkKey); ++i) {
if (i != 0)
Serial.print(â ");
printHex2(nwkKey[i]);
Serial.println();
display_.drawString(0, 5, âNetwork Joinedâ);
// size, we donât use it in this example.
LMIC_setLinkCheckMode(0);
break;
case EV_JOIN_FAILED:
Serial.println(F(âEV_JOIN_FAILEDâ));
break;
case EV_REJOIN_FAILED:
Serial.println(F(âEV_REJOIN_FAILEDâ));
break;
break;
case EV_TXCOMPLETE:
Serial.println(F(âEV_TXCOMPLETE (includes waiting for RX windows)â));
display_.drawString(0, 3, âData Sentâ);
Serial.println(F(âReceived ackâ));
if (LMIC.dataLen) {
Serial.print(F(âReceived â));
Serial.print(LMIC.dataLen);
Serial.println(F(â bytes of payloadâ));display_.drawString(0, 4, "Data received"); Serial.println(F("Data is ")); // Change the following codes to process incoming data !! for (int counter = 0; counter < LMIC.dataLen; counter++) { Serial.print(LMIC.frame[LMIC.dataBeg + counter], HEX); } Serial.println(F(" ")); } else display_.drawString(0, 4, " "); // Schedule next transmission os_setTimedCallback( & sendjob, os_getTime() + sec2osticks(TX_INTERVAL), do_send); break;
case EV_LOST_TSYNC:
Serial.println(F(âEV_LOST_TSYNCâ));
break;
case EV_RESET:
Serial.println(F(âEV_RESETâ));
break;
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F(âEV_RXCOMPLETEâ));
break;
case EV_LINK_DEAD:
Serial.println(F(âEV_LINK_DEADâ));
break;
case EV_LINK_ALIVE:
Serial.println(F(âEV_LINK_ALIVEâ));
break;
case EV_TXSTART:
Serial.println(F(âEV_TXSTARTâ));
break;
case EV_TXCANCELED:
Serial.println(F(âEV_TXCANCELEDâ));
break;
case EV_JOIN_TXCOMPLETE:
Serial.println(F(âEV_JOIN_TXCOMPLETE: no JoinAcceptâ));
break;default:
break;
}void do_send(osjob_t * j) {
display_.clear();
display_.drawString(0, 0, âTTGO ESP32 LoRa Testâ);
Serial.println(F(âOP_TXRXPEND, not sendingâ));
} else {
LMIC_setTxData2(1, mydata, sizeof(mydata) - 1, 0);
Serial.println(F(âPacket queuedâ));
display_.drawString(0, 2, âPacket Queuedâ);
}void setup() {
delay(5000);
while (!Serial)
Serial.begin(9600);
Serial.println(F(âStartingâ));
display_.begin();
display_.setFont(u8x8_font_pxplusibmcgathin_r);
#ifdef CFG_in868
Serial.println(F(âModule Configured for Inidian LoRa band (865-867 MHz)â));
display_.drawString(0, 1, âUsing IN866 Bandâ);
#endif
// LMIC init
os_init();
LMIC_reset();
LMIC_setClockError(MAX_CLOCK_ERROR * 5 / 100);
do_send( & sendjob);
}void loop() {
//os_runloop_once();
delay(5000);
And result in gateway message is like below:
âdataâ: {
â@typeâ: âtype.googleapis.com/ttn.lorawan.v3.GatewayUplinkMessageâ,
âmessageâ: {
âraw_payloadâ: âAHK4ANB+1bNwFtsfAAujBACFUITGZ/o=â,
âpayloadâ: {
âm_hdrâ: {},
âmicâ: âhMZn+g==â,
âjoin_request_payloadâ: {
âjoin_euiâ: â70B3D57ED000B872â,
âdev_euiâ: â0004A30B001FDB16â,
âdev_nonceâ: â5085â
I see that join_eui and dev_eui are different and I have no idea why.
I tried to set those values to new device in app but Iâm receiving message: âMIC mismatchâ - probably that AppKey is incorrect - but I have no idea how to reach proper one.
