Hi everyone,
I’m trying to OTAA connect using ISP4520 LoRa module.
I use ISP4520-example on GitHub.
Project file: ISP4520-examples/src/apps/lorawan/class_A/ses/class-A.emProject
The edited se-identity.h is as attached.
se-identity.txt (26.2 KB)
The Things Network V3 Settings:
Asia 920-923 MHz with LBT
LoRaWAN Specification 1.0.2
RP001 Regional Parameters 1.0.2 revision B
Activation mode: OTAA
Additional LoRaWAN class capabilities: None(Class A only)
Network defaults: Use network’s default MAC settings
DevEUI: 70 B3 D5 7E D0 04 F6 EF (generated by TTN)
AppEUI: 00 00 00 00 00 00 00 00 (generated by TTN)
AppKey: CA 95 FF C9 3C 4E C0 44 E0 FF EE D9 4F 7D D3 48 (generated by TTN)
Live data shows MIC mismatch. Am I in the wrong place to edit the parameters?
How can I resolve this error?
Kiyoshi
