Metadata from more gateways
I am working on my new project with TTN. I need to extract metadata and save it to my PC. Problem is that i see metadata only from one of my two gateways.
First gateway is single channel gateway dragino LG01-P and the second is raspberry pi with IC880a. If I switch on only one of this gateway all is working as I expect. But when I switch on both gateways, I see metadata only from raspberry pi and IC880a. What can be problem please?
Each gateway is placed on the other side of my house. Sensor is placed near dragino gateway. I use sensor with lmic library and I set the frequencies to 868.1 MHz and SF to 7, because single channel gateway.
gw1 obrázok
That is not a gateway and disrupts correct functioning of TTN, please switch it off now. You are already noticing issues with it, so will others.
(Your issue is caused by data arriving at TTN with too much delay between the packets from your gateway and from the lg01)
