I purchased a Dragino LSN50 Node (AU915) with water sensor and tried to connect to public gateways in Melbourne CBD last night but could not. After device registered stays remains “never seen”.
Dragino support advise Node with 915 spec, can only connect with gateway with 915 spec.
One of the gateway owners advised his Melbourne gateways are 923 standard.
So…is there a way to tell from the TTN Gateway coverage map if a gateway is 915 or 923?
https://www.thethingsnetwork.org/community/melbourne/
Nick
