Looks like I’ve cracked it on my side…
I experimented with the connections & found that leaving the RESET line unconnected on the RFM95W resulted in successful transmissions. This is what I get on the console now:
Mbed LoRaWANStack initialized
CONFIRMED message retries : 3
Adaptive data rate (ADR) - Enabled
[DBG ][LSTK]: Initiating OTAA
[DBG ][LSTK]: Sending Join Request …
[DBG ][LMAC]: Frame prepared to send at port 0
[DBG ][LMAC]: TX: Channel=2, TX DR=5, RX1 DR=5
Connection - In Progress …
[DBG ][LSTK]: Transmission completed
[DBG ][LMAC]: RX1 slot open, Freq = 868500000
[DBG ][LMAC]: RX2 slot open, Freq = 869525000
[DBG ][LMAC]: TX: Channel=2, TX DR=4, RX1 DR=4
[DBG ][LMAC]: DC enforced: Transmitting in 5538 ms
[DBG ][LMAC]: TX: Channel=0, TX DR=3, RX1 DR=3
[DBG ][LMAC]: RX1 slot open, Freq = 868100000
[DBG ][LSTK]: OTAA Connection OK!
Connection - Successful
Dummy Sensor Value = 3
[INFO][LMAC]: RTS = 23 bytes, PEND = 0, Port: 15
[DBG ][LMAC]: Frame prepared to send at port 15
[DBG ][LMAC]: TX: Channel=3, TX DR=3, RX1 DR=3
23 bytes scheduled for transmission
[DBG ][LMAC]: RX1 slot open, Freq = 867100000
Message Sent to Network Server
Dummy Sensor Value = 5
[DBG ][LMAC]: DC enforced: Transmitting in 12807 ms
My mbed_app.json setup:
"config": {
"lora-radio": {
"help": "Which radio to use (options: SX126X, SX1272, SX1276) -- See config/ dir for example configs",
"value": "SX1276"
"main_stack_size": { "value": 4096 },
"lora-spi-mosi": { "value": "p5" },
"lora-spi-miso": { "value": "p6" },
"lora-spi-sclk": { "value": "p7" },
"lora-cs": { "value": "p8" },
"lora-reset": { "value": "p11" },
"lora-dio0": { "value": "p28" },
"lora-dio1": { "value": "p27" },
"lora-dio2": { "value": "p26" },
"lora-dio3": { "value": "p30" },
"lora-dio4": { "value": "p29" },
"lora-dio5": { "value": "p12" },
"lora-rf-switch-ctl1": { "value": "NC" },
"lora-rf-switch-ctl2": { "value": "NC" },
"lora-txctl": { "value": "NC" },
"lora-rxctl": { "value": "NC" },
"lora-ant-switch": { "value": "NC" },
"lora-pwr-amp-ctl": { "value": "NC" },
"lora-tcxo": { "value": "NC" }
"target_overrides": {
"mbed-trace.enable": 1,
"platform.stdio-convert-newlines": true,
"platform.stdio-baud-rate": 115200,
"platform.default-serial-baud-rate": 115200,
"lora.over-the-air-activation": true,
"lora.duty-cycle-on": true,
"lora.phy": "EU868",
"lora.device-eui": "{ 0x00, etc..................
Hope this helps & best of luck!
