Hello @LoRaTracker, how is going? Exactly, but in my country there is no such limitation, and it would only be for exams and documents. Do you have any idea how to help me?
Or you could read the source code for LMIC (like I did) and then read the spec sheet for the SX1276 (like I did) and run some software tests (like I did) and then you will deserve your degree.
Most, but not all SX1276 based modules use the PA-BOOST pin for RF output.
Some SX1276 modules will use the RFO_HF pin for RF output, the SX1276 datasheet should be studied for the details of the differences and maximum available power etc.
Uolll @descartes , take easy man!! I don’t speak English very well, I usually use google translated. He translated “test” as “exam”. I’m not taking an exam, a school exam.
It’s for my bench test.
I admire your intelligence in setting up all this alone, but I don’t know, because I asked for help! If you can help me, i will thank you
Google for sx1276 and you will find the datasheet on the Semtech website. At least that is where I found it when I entered the part name 10 minutes ago.
Once you studied that datasheet you will probably need to look at the datasheet for the module you are using as you will need to know which output is connected to the antenna. Not knowing which module you use I can’t help you find it.
Btw I am going to remove one of your posts as as a moderator I do find it not in line with forum policy. Just so you know who removed it and why.
@kersing , when you said datasheet, I thought it was strange, I thought it would be a LMIC library documentation, but no, it’s the SX1276 -RFM95W 915Mhz document. I’ll start with him.
