For Node experimenters, there is a LoraWAN dev board called Colorbrick not covered here yet afaik.
Any experiences building nodes based on the OM series module are welcome.
Produced by Manthink
Frequency range 410~510MHz(OM422) 860~1020MHz(OM822)
Frequency step 1kHz
RF output power 5 ~ 20dBm
Reception sensitivity -138dBm @292bps
Air bandrate 292bps~5.4kbps
Emission current (typical value) 90mA@20dBm
Supply voltage 2.6~ 3.6V
ESD(Human Body Model) 2000V
Current in transmit mode 90mA @20dBm
Harmonic ≤1GHz:<-36dBm, >1GHz:< -30dBm
CAD/received Current 7mA
Sleep current 3μA
Size 40mm x 40mm
Antenna Impedance 50Ω
Working voltage 2.2V-3.6V
Working temperature -40℃~85℃
Working humidity 0%~95%RH
Link https://www.alibaba.com/product-detail/LoRa-LoRaWAN-developer-kit-code-open_1600158899917.html
