Make LGT-92-LI not transmit if it has no GPS fix?
Hello, all of you,
Is it possible to prohibit the emission in case of no GPS fix ?
Joseph.
Yes, write the code so if the status is no fix, it doesn’t send …
If you tell us which node you have, we can be more specific
He wrote in the title that it’s a dragino lgt-92-li.
It looks like the logic you need to alter is probably that associated with this part of their open sources:
You may end up needing to modify the called function and not just this part of main()
Thanks for your answer.
Joseph.
