i have a new MacBook Pro (13-inch, 2017, Four Thunderbolt 3 Ports) and I have to use a USB-C Adapter to connect the original The Things Uno to my Mac. I did everything what was described in the documentation, but my Arduino IDE does not find the port to connect to my uno. In Port I only see:
i fixed this issue. It seems that the preinstalled sketch makes some trouble so that the Uno is not visible in the Arduino IDE ports. But when I press the reset button on the Things Uno, the device is visible for about 8 seconds in ports. So I loaded the “DeviceInfo” Sample-Sketch in the Arduino, pressed the upload button in the IDE and after that, I pressed the reset button on the Arduino. Then there will be a 8 sek timeslot which is enough to upload the sketch and after that, my Things Uno was working normal and was always visible in the IDE.
