LR1302 LoRaWAN Gateway: Data Not Reaching TTN Server
Hello everyone,
I’m new to the world of LoRaWAN and have recently purchased the LR1302 gateway along with the hat for my Raspberry Pi. I’m excited to dive into this technology, but I’m facing a challenge that I hope you can help me with.
I am able to receive data successfully on the gateway, but unfortunately, it does not appear to connect to The Things Network (TTN). I’ve verified through a Wireshark capture that the data is being sent correctly from the gateway, but it still doesn’t show up as being online on the TTN dashboard.
Here are some details for reference:
Packet Forwarder Server Log:
INFO: Received pkt from mote: 8B904C0D (fcnt=16912)
JSON up: {"rxpk":[{"jver":1,"tmst":736331141,"chan":0,"rfch":1,"freq":868.100000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","rssis":-34,"lsnr":13.2,"foff":-885,"rssi":-33,"size":23,"data":"AA1MkItVEEKeEboG0H7Vs3B1AGNESUY="}]}
INFO: [up] PUSH_ACK received in 40 ms
INFO: [down] PULL_ACK received in 38 ms
##### 2024-11-05 18:08:45 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 1
# CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# RF packets forwarded: 1 (23 bytes)
# PUSH_DATA datagrams sent: 2 (374 bytes)
# PUSH_DATA acknowledged: 100.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (100.00% acknowledged)
# TX errors: 0
### SX1302 Status ###
# SX1302 counter (INST): 750831346
# SX1302 counter (PPS):  750301366
# BEACON queued: 0
# BEACON sent so far: 0
# BEACON rejected: 0
### [JIT] ###
src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
### [GPS] ###
# GPS sync is disabled
### Concentrator temperature: 25 C ###
##### END #####
JSON up: {"stat":{"time":"2024-11-05 18:08:45 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":100.0,"dwnb":0,"txnb":0,"temp":25.4}}
INFO: [up] PUSH_ACK received in 57 ms
INFO: [down] PULL_ACK received in 44 ms
##### 2024-11-05 18:09:15 GMT #####
### [UPSTREAM] ###
# PUSH_DATA datagrams sent: 1 (125 bytes)
# TX errors: 0
# SX1302 counter (INST): 780836493
# SX1302 counter (PPS):  780301324
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
##### END #####
JSON up: {"stat":{"time":"2024-11-05 18:09:15 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"temp":25.4}}
INFO: [up] PUSH_ACK received in 42 ms
JSON up: {"rxpk":[{"jver":1,"tmst":783651717,"chan":2,"rfch":1,"freq":868.500000,"mid": 9,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","rssis":-35,"lsnr":10.2,"foff":-909,"rssi":-35,"size":23,"data":"AA1MkItVEEKeEboG0H7Vs3B2AFr+9bc="}]}
INFO: [up] PUSH_ACK received in 41 ms
INFO: [down] PULL_ACK received in 84 ms
INFO: [down] PULL_ACK received in 42 ms
INFO: [down] PULL_ACK received in 39 ms
Wireshark capture:
eu1.cloud.thethings.network → 52.212.223.226
My configuration:
    "SX130x_conf": {
        "com_type": "SPI",
        "com_path": "/dev/spidev0.0",
        "lorawan_public": true,
        "clksrc": 0,
        "antenna_gain": 5,
        "full_duplex": false,
        "fine_timestamp": {
            "enable": false,
            "mode": "all_sf"
        "sx1261_conf": {
            "spi_path": "/dev/spidev0.1",
            "rssi_offset": 0,
            "spectral_scan": {
                "enable": false,
                "freq_start": 867100000,
                "nb_chan": 8,
                "nb_scan": 2000,
                "pace_s": 10
            "lbt": {
                "enable": false,
                "rssi_target": -70,
                "channels":[
                    { "freq_hz": 867100000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 867300000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 867500000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 867700000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 867900000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 868100000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 868300000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 868500000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 869525000, "bandwidth": 125000, "scan_time_us": 5000, "transmit_time_ms": 4000 },
                    { "freq_hz": 868300000, "bandwidth": 250000, "scan_time_us": 128,  "transmit_time_ms": 400 }
        "radio_0": {
            "enable": true,
            "type": "SX1250",
            "freq": 867500000,
            "rssi_offset": -215.4,
            "rssi_tcomp": {"coeff_a": 0, "coeff_b": 0, "coeff_c": 20.41, "coeff_d": 2162.56, "coeff_e": 0},
            "tx_enable": true,
            "tx_freq_min": 863000000,
            "tx_freq_max": 870000000,
            "tx_gain_lut":[
                {"rf_power": 12, "pa_gain": 0, "pwr_idx": 15},
                {"rf_power": 13, "pa_gain": 0, "pwr_idx": 16},
                {"rf_power": 14, "pa_gain": 0, "pwr_idx": 17},
                {"rf_power": 15, "pa_gain": 0, "pwr_idx": 19},
                {"rf_power": 16, "pa_gain": 0, "pwr_idx": 20},
                {"rf_power": 17, "pa_gain": 0, "pwr_idx": 22},
                {"rf_power": 18, "pa_gain": 1, "pwr_idx": 1},
                {"rf_power": 19, "pa_gain": 1, "pwr_idx": 2},
                {"rf_power": 20, "pa_gain": 1, "pwr_idx": 3},
                {"rf_power": 21, "pa_gain": 1, "pwr_idx": 4},
                {"rf_power": 22, "pa_gain": 1, "pwr_idx": 5},
                {"rf_power": 23, "pa_gain": 1, "pwr_idx": 6},
                {"rf_power": 24, "pa_gain": 1, "pwr_idx": 7},
                {"rf_power": 25, "pa_gain": 1, "pwr_idx": 9},
                {"rf_power": 26, "pa_gain": 1, "pwr_idx": 11},
                {"rf_power": 27, "pa_gain": 1, "pwr_idx": 14}
        "radio_1": {
            "enable": true,
            "type": "SX1250",
            "freq": 868500000,
            "tx_enable": false
        "chan_multiSF_All": {"spreading_factor_enable": [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
        "chan_multiSF_0": {"enable": true, "radio": 1, "if": -400000},
        "chan_multiSF_1": {"enable": true, "radio": 1, "if": -200000},
        "chan_multiSF_2": {"enable": true, "radio": 1, "if":  0},
        "chan_multiSF_3": {"enable": true, "radio": 0, "if": -400000},
        "chan_multiSF_4": {"enable": true, "radio": 0, "if": -200000},
        "chan_multiSF_5": {"enable": true, "radio": 0, "if":  0},
        "chan_multiSF_6": {"enable": true, "radio": 0, "if":  200000},
        "chan_multiSF_7": {"enable": true, "radio": 0, "if":  400000},
        "chan_Lora_std":  {"enable": true, "radio": 1, "if": -200000, "bandwidth": 250000, "spread_factor": 7,
                           "implicit_hdr": false, "implicit_payload_length": 17, "implicit_crc_en": false, "implicit_coderate": 1},
        "chan_FSK":       {"enable": true, "radio": 1, "if":  300000, "bandwidth": 125000, "datarate": 50000}
    "gateway_conf": {
        "gateway_ID": "7e8a7400a5e7d11e",
        "server_address": "eu1.cloud.thethings.network",
        "serv_port_up": 1700,
        "serv_port_down": 1700,
        "keepalive_interval": 10,
        "stat_interval": 30,
        "push_timeout_ms": 100,
        "forward_crc_valid": true,
        "forward_crc_error": false,
        "forward_crc_disabled": false,
        "gps_tty_path": "",
        "ref_latitude": 0.0,
        "ref_longitude":  0.0,
        "ref_altitude": 0.0,
        "beacon_period": 0,
        "beacon_freq_hz": 869525000,
        "beacon_datarate": 9,
        "beacon_bw_hz": 125000,
        "beacon_power": 26,
        "beacon_infodesc": 0
    "debug_conf": {
        "ref_payload":[
            {"id": "0xCAFE1234"},
            {"id": "0xCAFE2345"}
        "log_file": "loragw_hal.log"
TTN :
Thank you in advance for your help!
You’ve redacted the most important information which is of public record across the whole network.
The most certain way to get a global_conf.json file is to download it from the gateway page. Yours doesn’t look much like the one that TTN provides.
The most important thing to know is that the gateway id in the conf file should be under that big black stripe - it is the gateway EUI.
The second rule of gateway install club is having a known good device - because the first rule of gateway install club is that the disconnect status is almost slightly not quite meaningless as it doesn’t get updated in real time - it’s uplinks showing in the console that really counts.
Oh, alright! The EUI of the gateway is 00016C001F1D353B. For the setup, I’m using the packet forwarder configuration for the Electrow HAT, which is a fork of the Semtech packet forwarder.
I hadn’t realized that the “gateway_ID” value needed to be set to the gateway’s EUI. With the correct value in the configuration, it’s working much better now!
Thanks for the quick response and the helpful tips!
I’m really happy that everything is up and running now! :smiley:
Solution
“gateway_ID” is not the Gateway ID from the console; it should be the EUI!
 "gateway_conf": {
        "gateway_ID": "00016C001F1D353B",  <---- Gateway EUI
        "gps_tty_path": "/dev/ttyS0",
        "beacon_period": 0,
        "beacon_power": 26,
The success:
